Home > Puma (Tdci) > ?? Early Puma service action Rear A bar ???
TJ101
Has anyone heard of problem with the welding of the base or support of the rear A bar. The problem would be related to LR Defender 90, 110 and 130 with VIN numbers between LD736064 and LD752152,
Question asked by Santiago on another forum,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3766 11th Sep 2008 7:46am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I'm sure I saw a notice about this somewhere when I was looking into buying my Puma. I think it was to do with the very early units.
Found it: http://www.aulro.com/afvb/90-110-130-defen...post773558 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3768 11th Sep 2008 8:15am
Eduardo
Hi everyone!
I heard that also,
Appeared in the spanish and Latam forums at the begining of the year.
According to GTR they issued a service action comming in 2 flavours Q036 UK and Q036 EX.
The modification should be done at the first possible service.
Main problem was a change in specification were the A frame were welded instead bolted.
Its is not a recall but looks like.
In order to see if you have the problem, you must to inspect the A bar to see if its welded or bolted
Regards Eduardo
Post #3775 11th Sep 2008 12:55pm
mse
So is it the really early ones or all up to 08? Mike
Post #3777 11th Sep 2008 3:24pm
Eduardo
MSE
Only 2007MY are involved. The Service Action was issued on February 2008 and stated that the problem were already solved at this date. The problem involved VIN LD736064 to LD752152 if you like to check.
Regards Eduardo
Post #3784 11th Sep 2008 3:44pm
mse
Ill see - i wouldnt be surprised if mine has it Laughing Mike
Post #3797 11th Sep 2008 8:07pm
Eduardo
Laughing Laughing
Well at least mine is free of that! Eduardo
Post #3799 11th Sep 2008 8:25pm
