![]() | Home > Puma (Tdci) > ?? Early Puma service action Rear A bar ??? |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
I'm sure I saw a notice about this somewhere when I was looking into buying my Puma. I think it was to do with the very early units.
Found it: http://www.aulro.com/afvb/90-110-130-defen...post773558 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi everyone!
I heard that also, Appeared in the spanish and Latam forums at the begining of the year. According to GTR they issued a service action comming in 2 flavours Q036 UK and Q036 EX. The modification should be done at the first possible service. Main problem was a change in specification were the A frame were welded instead bolted. Its is not a recall but looks like. In order to see if you have the problem, you must to inspect the A bar to see if its welded or bolted Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
So is it the really early ones or all up to 08? Mike
MSE
Only 2007MY are involved. The Service Action was issued on February 2008 and stated that the problem were already solved at this date. The problem involved VIN LD736064 to LD752152 if you like to check. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Ill see - i wouldnt be surprised if mine has it
![]() ![]() Well at least mine is free of that! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
