Home > Puma (Tdci) > Rear Heater Blower
Dieselhead
Rear Heater Blower
Dont know if its been asked before.
Has anybody managed to fit a rear heater blower which runs from the front??
I know some are using diesel heaters, but can any pipe work be made up??
Thanks Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #378789 13th Dec 2014 10:02pm
munch90
Not what your looking for, but I have seen a series 3 with a small household radiator fitted in the back and it was bl@@dy brilliant
Post #378790 13th Dec 2014 10:06pm
munch90
Something like this
eBay Item No. 201220150656
Post #378791 13th Dec 2014 10:10pm
Dieselhead
Interesting Thanks.
Bit over my price range Crying or Very sad Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #378792 13th Dec 2014 10:14pm
munch90
Yea bit pricey , but think it would suit , old and new look etc
Mini is a self contained unit , matrix and fan in one unit ,
might not look the best to be honest
Post #378794 13th Dec 2014 10:20pm
LR90XS2011
look up Maradyne on google
http://cdn3.volusion.com/syzrq.xwfmv/v/vsp...012-2T.jpg DEFENDER 90 TDCI XS,
Post #378803 13th Dec 2014 11:21pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
When I bought my 110 V8, it had an enormous cubby box fitted with what I think is a standard LR heater matrix nad fan t-eed in to the coolant circuit, in series with the LPG vaporiser. It's one of the best things about the vehicle, as far as the children are concerned. In the Defender, when it is cold, it takes an age for the rear footwell to warm up and when it is really cold it simply doesn't.
Post #378807 14th Dec 2014 12:22am
dgardel
Italy
any pics? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #378809 14th Dec 2014 12:41am
Cheshire110
I've definitely seen an arrangement where the air from the 'down' (footwell) setting is diverted via two tubes to out the back of the centre cubby. Cheers, David
Post #378812 14th Dec 2014 1:18am
PaulMc
Have a look at what they sell here - http://stores.ebay.co.uk/theheaterstore
. Paul.
Post #378813 14th Dec 2014 4:42am
Dieselhead
Thanks for the links Thumbs Up
Thats the sort of thing, but its working out where to put a unit. Under the rear seats??
Also running the pipe work to it should not be to bad. Just tap into the pipes in engine bay & route along chassis & up & in
Anybody done an extra heater in a Puma yet?? Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #378818 14th Dec 2014 7:03am
munch90
how would you plumb in the aux heater ?
tee into std heater pipes , possible air lock problems with coolant not being pushed in one length direction ? ( this way your adding onto primary cooling circuit , but not in a one pipe length circuit if that makes any sense )
or take feed to aux heater from outlet to std heater , then aux outlet to std heater return pipe to the engine , so really coolant is pumped round in one direction still ? (this way your adding to primary cooling circuit , but in one pipe length , ok I know your using water that's already been through std heater , but guess it would still be hot enough to use again )
not sure ? never done it myself
Post #378831 14th Dec 2014 8:57am
Inigo
Please see enclosed pics of my rear heater, installed by PO. He was a boat builder, so everything is made out of wood/mdf where possible. The cubby is enormous, but the heater does work remarkably well for heating the kids feet in winter.
It is in a V8, so no worries about removing too much heat from the engine - perhaps that might be an issue with modern diesels?
Post #379653 17th Dec 2014 12:52pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
I've been following this thread with interest as thinking about the same for my 110 SW and heating for the passengers (ie kids) in the back.
I like the look of the sa12-5000-3 (http://www.ebay.co.uk/itm/SA12-5000-3-12-V...1199118786), but as this draws 50amps I was wondering if the alternator would be okay with extra draw on a cold morning just after starting?
I was thinking about mounting under the second row of seats.
Thoughts.....
Post #379665 17th Dec 2014 1:42pm
jst
alt will be fine, it depends on the battery and how long its going to run for before being turned off again and expecting restart. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #379700 17th Dec 2014 5:30pm
