Home > Maintenance & Modifications > rear middle door electric windows |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
has anyone do that?
any ideas? www.newfoundland.gr |
11th Aug 2010 8:13am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
pouf
I seen one some time ago in a TD5. they used a scrapped motor and mechanism from other TD5. Works OK. Probably alsio you can use those system to transform manual to electric ones with more less the same results Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
11th Aug 2010 3:55pm |
if i understand right, you take the mecanism of the front window and you transform it to the rear door.
brilliant idea thanks a lot eduardo!!!!! www.newfoundland.gr |
11th Aug 2010 8:45pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Along time ago when god was a boy there used to be kits that had external motors ie a plastic box that piped over the handle spline nice
12th Aug 2010 3:56am |
-only a weimaranerer could anwser that
-BigRuss, you have to be sure we will find a solution if there is any www.newfoundland.gr Last edited by pouf on 12th Aug 2010 9:57am. Edited 1 time in total |
12th Aug 2010 6:46am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
12th Aug 2010 9:17am |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
I saw an advertisement in one of my French magazines for such a kit. I'll have a look for it. 130 crew cab
98 V8 Disco |
15th Aug 2010 8:06pm |
Here's a link for the kit i'm thinking of fitting.
http://www.spal.it/default.php?t=site&pgid=44 They have two kits available, Universal model 140euros or original model 300euros. 130 crew cab 98 V8 Disco |
17th Aug 2010 5:41pm |
