Home > Wheels & Tyres > ZU's / Mach 5's / Terrafirma's |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
You dont need beadlockers, a defender with 285s at 15psi will go everywhere you will ever need to in the sand You cannot teach stupid people to do clever things
10th Aug 2010 10:13pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2955 |
silverline black sport bfg 255/85x16 mud awesome
10th Aug 2010 10:39pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Don't listen to the Dell Boy He wants Bead Lockers really Each of those are great in there own way me I love the terrafirma with BL's but modulars going on for the Winter because of the road salt weird I know I'm not worried about marks from lanes / shoots but corrosion on the nuts will drive me crazy |
11th Aug 2010 5:25am |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
11th Aug 2010 6:18am |
You don't need to necessarily stick with a 16 X 8 size wheel...With careful consideration of wheel/tyre size and offset you can achieve almost anything and change the look quite considerably. For example I run on 15 X 10 with a tyre flotation size of 32 X 11.5 which gave me almost the same rolling radius as original. My offset at 40mm is quite large but I like the 'Tonka Toy look.' It's all down to personal choice, but with a little calculation and imagination????
Matt Lee who was the original manufacturer of Mach 5s has only just gone back into production and I believe initially he will only be manufacturing beadlockers with the new flared spoke styling (IF you can get them?). Here: http://www.mjloffroad.com/pages.php?pid=14 The new design for 2009 bit didn't get off the ground with regards to full scale production. Another thread I started sometime ago about Mach 5s here: http://www.defender2.net/forum/topic2610.html?highlight=mach Beadlockers aren't really required unless you are going 'serious off-road' and can be notoriously difficult to balance (Sonic gave up in the end on a set of beadlockers due to balancing issues - see thread above). With Mach 5s which I hasten to add was my choice, availability is the key....I may be wrong but I doubt if you will be able to source a complete brand new set. I had to purchase three black and one stainless and get the stainless powder coated at the same place as the other three in the particular size and offset I researched as I really wanted to retain original rolling radius. At that time due to the harsh Winter I think I also could not get BF Goodrich KM2s in the size I wanted they were on a 6 week back order, quite often you may not be able to get what you decide upon so remain flexible and check availability before finally deciding to avoid disappointment. Mach 5s come in different sizes and offsets with ZUs the sizes and offsets are very limited in comparison. It depends on what look and style you wish to achieve and whether you want steel or alloy as Mach 5s are steel. Happy hunting and don't forget to post your end result.
Buy some decent nuts and corrosion will be a thing of history.....Not cheap! I did! And it is a thing of history! 10" width 15" diameter...... About £320 per corner complete....same look can be achieved with modulars at about £180 per corner.... Hope this helps....Mach 5 everytime for me!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 11th Aug 2010 8:01am. Edited 17 times in total |
11th Aug 2010 6:53am |
Sonics just a Wimp if you have the time and Patience you can balance to within 5g (Standard Car) but its something a normal tyre shop will wince at I'm sure Andy @ AJS would have had experience in them but understandably don't expect to pay the standard balance rate mucho beer tokens required & deserved
11th Aug 2010 6:59am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 |
whats the legality of beadlocks for on road use?
you wont need beadlocks for Maroc or CB. i am not entirely sure why you would want beadlocks for a road goign vehicle anyway to be honest - less bling factor - and yes they do look good. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
11th Aug 2010 9:18am |
Well I'm not worried about balancing the wheels, but if your taking your wheels off for the winter Ken. What are you putting on instead??
I plan on keeping the boost alloys possibly wrap them with some different rubber but I want the muds on over winter. It was great up in scotland this year and we've already had predictions of snow next month. With all this in mind I think I'm gonna toss the terrafirmas to the way side (but I do like them) and look at the ZU and Mach 5's. I've just got to consider alloy or metal (cost too), not to forget I need to decide what size rubber to use. Cheers for all the help guys Russell |
11th Aug 2010 11:35am |
I'm fitting Modulars with BFG KO's on
its the BL bolts that will corrode not the wheel nuts Oh why BL caus they bring the rim out to 8J |
11th Aug 2010 12:21pm |
If beadlockers bolts corrode as Ken says and the Mach 5s are like hen's teeth like I suspect, I think ZUs may be your only remaining option out of your choices. Devon do have some Staun Beadlockers on 'special' but I don't think they're your size specified. Alternatively get some decent boots for Winter use on your boosts and run two sets. Sure Ken'll do you a good boot price.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Aug 2010 12:54pm |
The question is can Ken get me a good price on wheels as well????
11th Aug 2010 1:30pm |
Fraid not Andy AJS has Defender Wheel tyre combos from time to time
11th Aug 2010 1:53pm |
I best get some 2nd wheels as well then these wont last 2 minutes in salt
You cannot teach stupid people to do clever things |
11th Aug 2010 2:11pm |
Heyyy! Good looking! Blingety bling Disco! Apologies if I spoke out of turn and was being presumptuous on boot prices Ken! If you go through life with your head in the sand....all people will see is an ar5e!!
11th Aug 2010 2:27pm |
