Home > Maintenance & Modifications > Another Webasto Thread- but with a Tdi
Page 2 of 5 <12345>
shaggydog
Thanks for the heads up Veetee Thumbs Up
I'm hoping to get it wired into a second battery so should have its own fused feed Very Happy
Just trying to find a nicer way to add a timer than the one supplied.
The one supplied while being simple looks a bit like its from a central heating boiler Laughing Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #375274 30th Nov 2014 5:33pm
VeeTee
Netherlands
Which one (timer) do you have now? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #375298 30th Nov 2014 6:37pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
I've bought timers etc from these people,they have an ebay shop also
http://butlertechnik.com
Post #375299 30th Nov 2014 6:40pm
shaggydog
This one came with the kit.
I'm not too keen on it.... Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #375307 30th Nov 2014 6:57pm
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
You seem to be always one Prodject ahead of me Laughing did you ever get this working (of course you did) Thumbs Up 2005 TD5 90 CSW XS
Post #377760 10th Dec 2014 7:11am
shaggydog
Ha!
Sadly not, its still sat on my work bench awaiting some tubing and wiring and the time to fit it.
I have a plan though, still working it out though. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #377948 10th Dec 2014 9:40pm
Kent_keith
Thumbs Up ok, just started reading your other Prodject thread, 4 pages in I thought Jesus!!!! Not something I would attempt unless I was retired and won the lottery Rolling with laughter respect though Thumbs Up Thumbs Up 2005 TD5 90 CSW XS
Post #378026 11th Dec 2014 6:09am
shaggydog
Hoping to get another update done on that this weekend Very Happy
Thank you! Glad your enjoying it Very Happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #378238 11th Dec 2014 8:49pm
jst
i would use that outlet/inlet on your tank and just drop a pickup in by using a bent tube with correct thread insert to mount it. try a plumber supplies etc. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #378250 11th Dec 2014 9:25pm
shaggydog
Not had much to report on this thread however now the head is apart and she isn't going anywhere it has meant I can actually crack on with this.
I made a quick bracket up at work to support it which should give it nice stable base and am trying to figure out all the pipe connections.
2 things which cross my mind.
Firstly, what are the benefits of fitting a non return valve into the system like this?
Secondly, would a unused webasto setup make much difference in the running of the vehicle? I'm worried having now committed to rebuilding the head of now damaging it by fitting the webasto and it overheating when not being used? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #457854 24th Sep 2015 7:44pm
shaggydog
Bit of an awesome day today.
As everything was apart I decided to take my heater box out so I could inspect my heater matrix properly.
Much to my pleasant surprise it looks brand new! The gasket however is toast so new gaskets on order but it did mean that I could rivet the bracket which holds the circulating pump in place which annoyingly I couldn't do because of the angle.
Then had a bit of a fiddle around with my Webasto which in a fashion Heath Robinson would be proud of (jam jar fuel tank, lunchbox coolant tank, electrical tape connections) It fired up into action and within 5 mins the coolant was piping hot and it was heating away merrily!
After it had cooled down I set to work making the bracket which it fixes too. I used the Windscreen Washer bottle mount and made my own adapter plate which allows the Webasto to mount to the windscreen washer bottle. This worked surprisingly As expected and the whole thing is nice and sturdy.
Now just waiting on the gaskets for the heater box assembly to go back in, so I can start the fuel, electrical and plumbing connections
Some pics of the Webasto fitted on its mount
Post #458286 26th Sep 2015 11:05pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Shaggy,
Is this a different setup/type to the others normally seen located inside the cab area and blow heated air directly? Or have you found a more ingenious way to mount it?
Fancied a webcasts/eberspace but not keen on mounting it under the rear seat for fear of damaging when carrying longer loads
Apologies if you've previously mentioned this. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #458314 27th Sep 2015 7:58am
shaggydog
Hi Rosco,
I think what you are referring to is a air heater- this one is a coolant heater which pre-heats the engine coolant which helps with starting but more importantly in a Tdi it helps warm the engine up so the heater works quicker!
I did look at getting a air heater but I reckoned that as I want to go and do more snowboarding a block heater will be more useful and does the same job as an air heater but with the additional benefit of less wear on the engine components due to easier starting etc.
Time will tell once it is set up how successful it is but judging by my Heath Robinson set up it should work very very well! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #458384 27th Sep 2015 11:37am
shaggydog
Bit of a boring video but here is it working away!
Post #458392 27th Sep 2015 11:55am
Rosco
Shaggy, realised the difference after a quick mooch around Webasto's website. Am I right in saying this system in effect provides hot air to the cabin without the engine running (although the ignition would be required to run the blower fan)? Or does it just pre-heat the block?
Either way I've been told I don't need one, as it already has a heater fitted. Rolling Eyes They never understand do they Laughing 2007 - Stornoway Grey 90 XS SW - Gone
Post #458595 28th Sep 2015 7:13am
Page 2 of 5 <12345>
