Home > Td5 > Another Headlight problem (all groan)
jhnstap
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
Help-advice needed please
Having had my headlights fail on me, I have trawled the forums, read all the posts and followed the advice given
# Changed headlight switch-worked but still failed
# Fitted Landreiziger loom (nice easy fit)
# Worked for a couple of days, but now intermittently failing
# Ran lights on test for 30 minutes all fine, turned switch off, turned on again and no lights
So would the switch which is only 6 weeks old have failed again? (have ordered another Lucas OEM switch to fit) my drive to work and home is in the dark so lights are on 2 hours a day
Could it be a problem within the original loom that is left in place?
Lights are JW Speakers so not drawing too much power
Roolites 170 linked into to be on with full beam only, (these work on flasher when lights have failed)
Have fitted LED upgraded sidelights with DLR's and all seem to be OK-rears and indicators work fine,
all wired back to a Blue Sea ST Blade Fuse Block in battery compartment, which has never given a problem.
Thanks for any advice that is forthcoming I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #377749 10th Dec 2014 5:42am
Do you still have the old switch ? What made it fail ? If it melted then too much current in your circuit
Are the spots on a relay ?
Post #377754 10th Dec 2014 6:45am
jhnstap
Switch
Steve (BP Man)
Switch looks fine when taken off, contacts look clean, no sign of melting, spots are on a relay, really scratching my head now I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #377757 10th Dec 2014 7:05am
Is the problem with dip beam, full beam or both ?
Post #377758 10th Dec 2014 7:08am
munch90
possible indicator/high/low stalk ?
Post #377759 10th Dec 2014 7:09am
jhnstap
Switch
Total head light failure on switch, If i pull stalk I get full beam no problem, indicator arm/switch was changed in November as well as a precaution
really appreciate the comments Thumbs Up I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #377761 10th Dec 2014 7:34am
Can you test the jws units?
Check battery box, fuse box .. If they are ok, looks like loom problems ..
Post #377768 10th Dec 2014 8:22am
It could be the relay which energizes with ignition on to power the headlights.
My approach would be to wait until the next failure then test with a voltmeter to see where I have power and where I do not. That should allow the fault to be isolated reasonably easily.
Post #377772 10th Dec 2014 9:15am
landy andy
Have you checked the fuse holders that came with the new headlight wiring loom? Thought someone had written that they had fuse holder fail?
Andy
Post #377774 10th Dec 2014 9:19am
NickH
England 2003 Defender 90 Td5 PU Rimini Red
I just had similar problem, intermittent headlight failure
Turned out to be dim dip unit so I bridged it like we used to do at the main stealers.
Perfect Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #377818 10th Dec 2014 12:55pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
Was a dodgy relay for me on the 300tdi a few months back, assumed wrongly it was the switch.
Should have used blackwolf method ... follow the electrons (or lack of), where are they, and where are they not. From supply to input to switch to output.. etc etc Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #377835 10th Dec 2014 2:31pm
jhnstap
Switch
Thanxs all, have a mates help today to try and trace fault few ideas to follow, so hopefully get it resolved-hate intermittent faults I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #378032 11th Dec 2014 7:25am
Well done .. Please keep us updated with the solution Thumbs Up
Post #378033 11th Dec 2014 7:27am
Orangeboy
My intermittent head light issue were all caused by a melted header ( blue plastic things )in the loom behind the dash.
A nail had got stuck and rubbed through part of the loom.
Flash would always work but the rest were intermittent
The time to find it that issue is what caused my defender to become a toy rather than my main car last winter
Post #378106 11th Dec 2014 12:36pm
jhnstap
Re: Switch
Checked connections and all looked good, pulled the headlight relay in front of gear lever (yellow and 3rd front right, 2 along from Immobiliser relay) and bottom/live pin was blued, and connection looked twisted, straightened out connection swapped relay with heated rear screen relay as they are the same, so now just have to monitor to see if fixed-if not carry on with process of elimination-hopeful heated rear screen plays up which will prove it was the relay-or not I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #378130 11th Dec 2014 3:16pm
