Home > Maintenance & Modifications > Side window demisters. |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 |
I fitted Defenderdenisters took all of two minutes no holes to cut and they work.
Uncas |
4th Dec 2014 5:29pm |
They look really ugly though
4th Dec 2014 5:45pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2644 |
Mine too http://www.retroanaconda.com/landrover/201...demisters/ |
4th Dec 2014 9:04pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
I knew I had cpopied someone Ray. But couldn't remember who! Thanks .
5th Dec 2014 8:33am |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 762 |
That's almost exactly how I did mine, I hadn't seen that set-up before but it looked to me to be the most obvious and successful option to try. As already stated, the advantage is that by drilling into the lower dash you aren't diverting air that was on its way to the windscreen demisters (wouldn't be a problem for me as I have a heated screen anyway but I just didn't like the idea). Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ONE LIFE, GET IT! |
5th Dec 2014 8:07pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
For those doing the mod you could always use these to neatly finish the job off on offer from Exmmoor trim
http://www.exmoortrim.co.uk/store/clearanc...etail.html |
5th Dec 2014 8:20pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
I've got the defender demisters, ugly and plasticky but they avoid pulling apart the dash which I've done so many times I refuse to do it again, and they work just as well as the other option.
5th Dec 2014 8:25pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
I did the demister mod today, same as retroanaconda's link. I used a 16mm internal diameter convoluted tubing (from an old wall paper stripper) and metal inserts for 15mm plastic plumbing pipe. You can definitely feel a blow and it doesn't seem to have affected the flow to the windscreen, just need to fog it up now to test it.
I was out at if from around 9 till 3, but some of that time was awaiting a dremmel and sorting out my mud console wiring, so it is probably a half day job 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
16th Dec 2014 5:16pm |
