Home > Maintenance & Modifications > Side window demisters.
Page 2 of 2 <12
uncas
I fitted Defenderdenisters took all of two minutes no holes to cut and they work.
Uncas
Post #376381 4th Dec 2014 6:29pm
mk1collector
They look really ugly though Whistle Rolling with laughter
Post #376388 4th Dec 2014 6:45pm
uncas
You can't call a anything on or about a Defender pretty can you except noisy, draughty and leaky. I didn't have to drill any holes in the dash and I can take them off and no one is the wiser
Uncas
Post #376440 4th Dec 2014 9:02pm
Retroanaconda
PaulMc wrote:
mk1collector wrote:
I didn't t in, I drilled holes next to the ducting into the airbox and pushed the convoluted tubing into it so you get a better flow of air to the side windows and don't interupt the flow to the windscreen.
That's how the Military demisters are fitted.
Mine too Smile
http://www.retroanaconda.com/landrover/201...demisters/
Post #376473 4th Dec 2014 10:04pm
kipperthedog
I knew I had cpopied someone Ray. But couldn't remember who! Thanks Thumbs Up .
Post #376529 5th Dec 2014 9:33am
Litch
PaulMc wrote:
Side Screen Demisting was fitted to the 'winterised' Military Defenders procured during 1991
I fitted these Military parts to my 110 around 1995, and it's well worth having Thumbs Up
Here are some pics of my installation -
Here's an extract from the Military Parts List -
The dealer looked-up the prices and wrote them against the part numbers - this was around 1995 IIRC.
The diagram doesn't make it very clear but, item #1 - Part No. RRC7316, is the adaptor that goes onto the new dash end pieces to enable the convoluted hoses to connect to them, you require 2 of this part (one for each side).
I think that you are also supposed to use 2 x RRC7316 to connect the side-screen convoluted hoses to the new dash closing panel, item #4 - RRC7320
I didn't buy the new dash closing panel or the adaptors for it, I used my existing dash closing panel and used a holesaw to cut two holes of the right diameter into it either side of the hole where the hose for the L/H windscreen demister outlet is connected (roughly where shown in the diagram) so that the new side-screen convoluted hoses are routed behind the bulge in the dash trim. I de-burred the edges of the new holes and with a pair of pliers I 'kinked' the hole so that the convoluted hoses screwed in to the panel. I then put sealer around the joint.
I'm not sure if any of these parts are still available from Land Rover - but, if they are, I expect that they're now silly-money.
That's almost exactly how I did mine, I hadn't seen that set-up before but it looked to me to be the most obvious and successful option to try. As already stated, the advantage is that by drilling into the lower dash you aren't diverting air that was on its way to the windscreen demisters (wouldn't be a problem for me as I have a heated screen anyway but I just didn't like the idea).
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ONE LIFE, GET IT!
Post #376685 5th Dec 2014 9:07pm
gilarion
For those doing the mod you could always use these to neatly finish the job off on offer from Exmmoor trim
http://www.exmoortrim.co.uk/store/clearanc...etail.html
Post #376689 5th Dec 2014 9:20pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I've got the defender demisters, ugly and plasticky but they avoid pulling apart the dash which I've done so many times I refuse to do it again, and they work just as well as the other option.
Post #376690 5th Dec 2014 9:25pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I did the demister mod today, same as retroanaconda's link. I used a 16mm internal diameter convoluted tubing (from an old wall paper stripper) and metal inserts for 15mm plastic plumbing pipe. You can definitely feel a blow and it doesn't seem to have affected the flow to the windscreen, just need to fog it up now to test it.
I was out at if from around 9 till 3, but some of that time was awaiting a dremmel and sorting out my mud console wiring, so it is probably a half day job 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #379461 16th Dec 2014 6:16pm
Page 2 of 2 <12
