Home > In Car Electronics > Sony head unit in to TD5
Northernremedy
United Kingdom 2004 Defender 110 Td5 CSW Aintree Green
Hello team!
So I'm thinking about fitting one of these into my 04 TD5,
http://www.halfords.com/sat-nav-audio/car-...-dab-radio
Can anyone see any issues or problems with doing so? In terms of changing do I just need the gadgets to whizz the old one out and then plug and play?
Thanks!
Post #376278 4th Dec 2014 9:18am
kipperthedog
Can't foresee any problems with this, but one piece of advice worth bearing in mind.....is that you should never rub your eyes when chopping onions!
Rolling with laughter
(though this is only funny if you are who I think you are!!!!!!)
Post #376361 4th Dec 2014 4:47pm
Northernremedy
Hahaha Simon you &@&##%^ Rolling with laughter
Post #376363 4th Dec 2014 4:51pm
Dale
United Kingdom 2001 Defender 110 Td5 Tomb Raider LE Bonatti Grey
My head unit just plugged straight in as had ISO connectors on unit and in vehicle wiring. You'll want a DAB aerial as well if you want to receive digital radio. I have a DAB radio in mine, and used a DAB aerial that sticks to inside of windscreen. I have it mounted at the top in the middle, so it is obscured by the rear view mirror. Very discrete, and the reception is fine everywhere I've been so far. They'll probably be a external microphone with the head unit for hands free calls, and again, mine is clipped to the headlining, and the cabling run above the headlining, down the A post, and behind the dash.
Post #376364 4th Dec 2014 4:51pm
kipperthedog
Thumbs Up Enduringly funny!! Rolling with laughter (though you had to be there admittedly).
Post #376371 4th Dec 2014 5:40pm
Northernremedy
Thanks Dale!
I'll let you know how I get on Simon Smile
Post #376392 4th Dec 2014 6:56pm
jimbob7
You might need an iso adaptor,remove your radio and call in at Halfords and they'll tell you which one you need. Pov.spec,ftw. 2006, 110,TD5.
Post #376568 5th Dec 2014 12:51pm
