Home > Td5 > How to remove td5 steering wheel |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Undo the center nut. stand in the driving position and put on the wheel it should come off.
2nd Dec 2014 10:20pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2212 |
Make sure you don't end up with a Broken nose
2nd Dec 2014 10:29pm |
/\ Too true
2nd Dec 2014 10:31pm |
Have you figured it out yet Brad ?
2nd Dec 2014 10:35pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
I bought a tool off eBay for a few ££'s. Works a treat, I've used it several times, it makes removing the wheel a doddle.
2nd Dec 2014 10:41pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
Loosen center nut but leave on, put knees under bottom of wheel, and a hand on the top of wheel, pull wheel with knees and hand whilst giving the center shaft a good tap with a soft hammer. That's my method, if pulling doesn't work.
Andy |
2nd Dec 2014 11:21pm |
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 |
I have a removal tool here. You're more than welcome to borrow it (by post, obviously...) Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
3rd Dec 2014 12:14am |
td590brad Member Since: 30 Nov 2014 Location: Sussex Posts: 203 |
So do I prize the Land Rover badge out and expect to see a nut ?
Thanks |
3rd Dec 2014 8:00am |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 574 |
Yup,prise the Landy badge out carefully with a flat blade screwdriver.Undoo nut,but dont take it off completely.Then try any or all of the above,et voila.Hopefuly,it will be off.
3rd Dec 2014 8:18am |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
Be careful if you use the hammer method as the shaft is collapsible.
3rd Dec 2014 10:58am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Having BIG trouble getting the wheel off the soft top, it's completely and utterly jammed.
Have tried a puller which pulled the threads out of the wheel Plus Gas hasn't unjammed it. Can't apply heat as the wheel will melt 1988 90 Td5 NAS soft top 2015 D90 XS SW |
3rd Dec 2014 11:56am |
How many splines and what steering wheel do you have. I have seen a few Defenders where some nutter in the past who owned the Defender has hammered on a 36 spline steering wheel on to a 48 spline shaft and once they do that it is near impossible to remove….
http://www.web-rover.co.uk/nav.php?p=articles/steeringwheels |
3rd Dec 2014 1:19pm |
That my old web site, I did the original research into these wheels
It's got the correct (36 spline) wheel on 1988 90 Td5 NAS soft top 2015 D90 XS SW |
3rd Dec 2014 1:24pm |
I have to say thank you then Martin as that web page over the years has come in very handy indeed
Glad its not a hammered on wheel anyway If all else fails trying to remove the steering wheel you could try a freeze spray. Then let it thaw, it just might break the grip of the two types of metal. |
3rd Dec 2014 2:13pm |
