Home > Td5 > How to remove td5 steering wheel
td590brad
United Kingdom 2008 Defender 90 Puma 2.4 CSW Santorini Black
Hi
Just wonderd how to remove a td5 defender steering wheel as I am going to fit a moto lita
Any help would be great
Thanks
Post #375968 2nd Dec 2014 11:17pm
JAY BOY
Wales
Undo the center nut. stand in the driving position and put on the wheel it should come off. Thumbs Up
Post #375973 2nd Dec 2014 11:20pm
keith
Make sure you don't end up with a Broken nose Whistle
Post #375978 2nd Dec 2014 11:29pm
JAY BOY
Wales
/\ Too true Rolling with laughter Rolling with laughter
Post #375979 2nd Dec 2014 11:31pm
keith
Have you figured it out yet Brad ? Laughing
Post #375980 2nd Dec 2014 11:35pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I bought a tool off eBay for a few ££'s. Works a treat, I've used it several times, it makes removing the wheel a doddle.
Post #375982 2nd Dec 2014 11:41pm
landy andy
Loosen center nut but leave on, put knees under bottom of wheel, and a hand on the top of wheel, pull wheel with knees and hand whilst giving the center shaft a good tap with a soft hammer. That's my method, if pulling doesn't work.
Andy
Post #375997 3rd Dec 2014 12:21am
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
Re: How to remove td5 steering wheel
Td590brad wrote:
Hi
Thanks
I have a removal tool here. You're more than welcome to borrow it (by post, obviously...) Very Happy
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #376001 3rd Dec 2014 1:14am
td590brad
So do I prize the Land Rover badge out and expect to see a nut ?
Thanks
Post #376014 3rd Dec 2014 9:00am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Yup,prise the Landy badge out carefully with a flat blade screwdriver.Undoo nut,but dont take it off completely.Then try any or all of the above,et voila.Hopefuly,it will be off.
Post #376018 3rd Dec 2014 9:18am
gilarion
Be careful if you use the hammer method as the shaft is collapsible.
Post #376034 3rd Dec 2014 11:58am
Martin
Site Admin
Having BIG trouble getting the wheel off the soft top, it's completely and utterly jammed.
Have tried a puller which pulled the threads out of the wheel Big Cry
Plus Gas hasn't unjammed it.
Can't apply heat as the wheel will melt Confused
Banging Head Banging Head  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #376041 3rd Dec 2014 12:56pm
gilarion
How many splines and what steering wheel do you have. I have seen a few Defenders where some nutter in the past who owned the Defender has hammered on a 36 spline steering wheel on to a 48 spline shaft and once they do that it is near impossible to remove….
http://www.web-rover.co.uk/nav.php?p=articles/steeringwheels
Post #376074 3rd Dec 2014 2:19pm
Martin
Site Admin
That my old web site, I did the original research into these wheels Wink
It's got the correct (36 spline) wheel on Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #376075 3rd Dec 2014 2:24pm
gilarion
I have to say thank you then Martin as that web page over the years has come in very handy indeed Thumbs Up
Glad its not a hammered on wheel anyway Very Happy
If all else fails trying to remove the steering wheel you could try a freeze spray. Then let it thaw, it just might break the grip of the two types of metal.
Post #376083 3rd Dec 2014 3:13pm
