Home > Wheels & Tyres > Advice.....
Grenadier
Advice.....
To all LR stats, pie-charts, tables and numbers fans, I need a little help.
I have recently upgraded my main wheel to an AR Casting F-15 (AKA Blindo) shoed with Cooper ST Maxx's. However I am looking to get a set of Nokian Hakkepelitta LT2 Winter tyres to pop on the original LR steel wheel (reconditioned from factory white to Matte Black). The wheels dimensions are listed as:
5.5 J16 33
I have no real idea how that translates to metric, so what would be the advice for the size of Nokian tyre needed for this wheel? Please note that I am keen to retain the 'taller' wall (it's just a look thing) but happy with a thinner profile as I know they work better in snow.
So what sizes would you recommend?
Thanks in advance..... Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #375476 1st Dec 2014 11:44am
mikeh501
235 I think 85/16
Post #375602 1st Dec 2014 6:45pm
JAY BOY
Wales
205/80/16 or 235/85/16 i think Exclamation
Post #375605 1st Dec 2014 6:49pm
Cupboard
According to the Nokian website, the following sizes are available for a 16" rim:
215/85 R 16
225/75 R 16
235/85 R 16
245/75 R 16
265/75 R 16
285/75 R 16
Most people reckon you're pushing it a bit putting 235/85s on a 5.5" rim, though it can be done. That's the size that is most commonly referred to as the metric equivalent of the 7.50s that are usually fitted on the standard steel rims.
Post #375710 1st Dec 2014 10:49pm
Grenadier
Many thanks Gentlemen. Think I am going with 245/75R 16s. Healthy wall height, with sensible profile... Monsieur Le Grenadier
Post #375746 2nd Dec 2014 8:07am
I wouldn't really recommend anything wider than 245 on a 5.5 inch rim, although you would probably be OK with 265.
Post #375763 2nd Dec 2014 9:47am
Cupboard
Question
Most people say 235s are pushing it on the standard steels.
255s tops on the Wolfs.
Whilst Nokian don't seem to list recommended rim sizes, Cooper and BF Goodrich say the largest you can put on the 5.5 is 215/85 (or lower profile 215s).
Post #376012 3rd Dec 2014 7:15am
nakatanenga
Germany
Use the 235/85R16 It fits perfect on the 5.5
With the 245 you will loose nearly 2cm ride height WANTED:
SII or SIII in max 1.5k
Post #376015 3rd Dec 2014 8:06am
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
I've just had LT2 235/85 x 16 fitted onto 7"wide rims and that was a struggle - according to tyre man.
They look OK but I can't imagine them fitting 5.5" rims without some serious swearing!
If you must stick with 5.5" rims, I'd opt for maximum 215mm wide tyres.
Best of luck Thumbs Up
LRmud
Post #376066 3rd Dec 2014 1:02pm
I have a set of 245/75 BFG Muds (the original pattern) fitted on genuine HD "Wolf" rims which I use on a trailer, and the tyre fitter didn't have any trouble fitting them.
I can't really see that putting 255/85s onto 7" rims was a struggle, unless the tyre fitter is someone who just doesn't like doing any work!
When I had the 285/75s fitted to my Boosts the fitter didn't have any trouble (same fitter as for the 245s). Perhaps it's because it's a tyre place that does agricultural and truck tyres, not just cars!
Post #376071 3rd Dec 2014 1:08pm
roel
The tyrefitter probably finds it a struggle as he normally does normal car tyres. Laughing
I fit these myself:
And these are 235 85 16 on 5,5" rims AFAIK Roel
2003 90 Td5 (2009-now)
Post #376079 3rd Dec 2014 1:58pm
leeds
Well we have just had a set of 255/85/16 BFG M/T. (Original pattern, thanks Peter Thumbs Up ) onto a set of Wolf rims.
No issue there as they were fitted by Four Plus 4 in Leeds and they are used to fitting 4x4 tyres and no issues Thumbs Up
Brendan
Post #376080 3rd Dec 2014 2:09pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
235/85R16 come standard on Defs nowedays.
245/75R16 are Disco 1 & 2 wheels, I think...???
for calculation purposes only:
235/85R16 =>
235 = tyre width in mm
85 = 85% of 235 = tyre height in mm
R16 = 16x25.4 mm wheel diameter
So complete height = 16x25.4 + 2x0.85x235 = 806 mm (current standard ?)
245/75R16 height = 774 mm (2 x 16 mm top and bottom less = 16 mm less rideheight !!!)
255/85R16 height = 840 mm (+17 mm ride height, but may be to wide for this rimm?)
265/75R16 height = 804 mm (-1 mm ride height, but may be to wide for this rimm?)
Post #376084 3rd Dec 2014 2:16pm
AJS4X4
235 section tyre is not recommended on a 5.5J wheel rim. Andy.
www.ajstyres.co.uk 01737 241370
Junction 8 M25 Surrey.
Post #376126 3rd Dec 2014 5:08pm
