Home > In Car Electronics > Switched live???
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Switched live???
OK,So,I spent the week-end fitting a lurvelypair of Exmoor trim seats,with Waeco heaters.
I have searched previous posts and found out that the red wire is permenent live,and the orange wire is switched live.I can pick up a permenent from the battery compartment,no problem,but.Where is the best place to pick up a switched live????
Thanks in advance.
Bow down Bow down Bow down
Marc.
Post #375432 1st Dec 2014 7:16am
K9F
These are for RHD but the colours will be the same....Happy Hunting.... Thumbs Up
http://api.viglink.com/api/click?format=go...Bwdo%253D1 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #375536 1st Dec 2014 3:37pm
Martin
Site Admin
White with a green stripe is ignition switched and fused 12V.
I assume the kit uses this feed to trigger a relay and not to power the seats?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375537 1st Dec 2014 3:40pm
sharkey964
Yes it triggers a relay.
Where can I find a white with green stripe?
Is it possible to pick up a switched live from the back of the fuse box.ie use one of the spare fuses or pigy back off something thats existing?
Post #375544 1st Dec 2014 4:08pm
K9F
Look at the link I posted....there's loads of switched lives in the diagrams and you can even find your 'green with white stripe' therein (Chapter 501-10 Seating). Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #375546 1st Dec 2014 4:17pm
Martin
Site Admin
Appreciate that the wiring diagrams can just look like a bunch of lines - may not be totally intuitive Wink
An 07 Puma will have plenty of switched live in the fuse box under the steering wheel Smile
Fuse 33 is the location of the factory heated seat fuse, you might be lucky and pick one up from there.
I assume a French spec XS doesn't have heated seats then?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375560 1st Dec 2014 5:08pm
sharkey964
Thanks guys,
I thought fuse 33 might be a good place to start.
My truck was origionaly a H/T.but with windows.
I am in the process of installing a S/W interieur.Or should I say the parts I like from a S/W.
Marc.
Post #375567 1st Dec 2014 5:30pm
K9F
Fuses 34 & 35 are also switched live for the windows if 33 isn't convenient. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #375578 1st Dec 2014 5:48pm
