Home > Technical > Front doors - remove pin?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi again,
Back again with what many would consider a trivial task, however I have a knack for making simple things difficult. Laughing
How do I remove the pin that keeps the front doors from flapping open all the way, the pin that secures them to the stays?
I need to open them further to remove the seal (upgrading with newer seals) and drill new holes. Figured I'd check first with knowledgable people rather than just jumping in and realising I'd bent/broken something.
Thanks!
Post #374303 26th Nov 2014 2:19pm
shaggydog
On my ones there is a split pin you pull out then withdraw the pin on the bulkhead end of the door strap.
Keep an eye out for any washers that may be between the pin and the strap.
You may have a plastic cover over it but this should be simple to remove. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #374375 26th Nov 2014 7:15pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I did this a few months ago:
http://defender90xs.blogspot.co.uk/2014/08...seals.html
The removed pin can be seen about half way down the page. http://defender90xs.blogspot.co.uk/
Post #374387 26th Nov 2014 7:38pm
eutek
Thanks for the help guys!
mark_d - this is exactly what I'm hoping to achieve, your blog is a great reference for the seal replacement.
thanks!
Post #374614 27th Nov 2014 4:14pm
