Home > Technical > Why do sidelight bulbs aways burn out in under a year?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Why do sidelight bulbs aways burn out in under a year, while others (turn signal, reverse etc) last for ages?
Confused
Post #374177 25th Nov 2014 5:30pm
Used the most, always on.
Worth checking the voltage on them though.
Post #374178 25th Nov 2014 5:42pm
mk1collector
I got annoyed with it today too after replacing 3 or 4 this year Rolling Eyes so nipped over to bolt on bits and got a pair of their rdx led sidelights so I'm hoping for no more problems for a good long time.
Ray
Post #374181 25th Nov 2014 6:01pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Are you buying dodgy bulbs from the same place? 1953 80"
1987 mini city e
2011 90"
Post #374209 25th Nov 2014 9:09pm
eutek
Hmmm... I'd have to break out my multimeter thing and then figure out how to use it. I've had it for about 20 years and used it... once. Embarassed Embarassed Embarassed
I usually buy the bulbs from Halfrauds. The seem to last about a year.
Post #374301 26th Nov 2014 2:14pm
Venomator
You really do need to upgrade to LED units... Mr. Green
A one off, plug and play replacement that will probably last longer than your truck... Whistle
And they're reasonably priced now, but very effective... Thumbs Up
And saves you breaking out your MM... Rolling with laughter
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #374304 26th Nov 2014 2:24pm
eutek
I'm very tempted. OK - now convinced. Very Happy
Chris at CSK gave me some LED replacements for the dome lights (which seemed to have a lifespan similar to the sidelights) and they're quite bright and likely to last forever.
LED is probably the way to go. Just replaced some halogen spots in the house with LEDs, much softer light and the room doesn't turn into a sauna.
Post #374306 26th Nov 2014 2:27pm
Venomator
These are the ones I went for, they are brilliant, literally, and the Seller is ace... Mr. Green
Clicky >
RDX LED Sidelight Rog... Mr. Green
The GREEN One...
Post #374309 26th Nov 2014 2:33pm
What he said ^^^^
Post #374312 26th Nov 2014 2:57pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Is it just me ? I've never changed one in mine (4 1/2 yrs). 2005 Td5 90 XS
Steve
Post #374384 26th Nov 2014 7:32pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Me neither 2002 110 td5
Post #374433 26th Nov 2014 10:18pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
5 years now and never replaced any exterior bulb - only 40K miles though, which probably helps.
Post #374467 27th Nov 2014 12:20am
Cheshire110
I've done 70k miles/4.5 years and never changed a bulb!!
You can get heavy duty bulbs, seen them in halfords. Supposed to be more vibration resistant and last longer. No experience of them though.
As above, voltage issue? Multiples per year sounds excessive unless you drive with side lights on all the time, in which case get some DRLs! Cheers, David
Post #374469 27th Nov 2014 12:31am
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
I've had the defender 11 years and only changed them all once, at about 9 years, because they were actually going black on the outside of the glass. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #374474 27th Nov 2014 5:52am
eutek
Thanks for the advice all... perhaps it has to do with where we live? We're up on top of a hill, it is always misty/damp here.
Anyway, will move to LEDs, enough of this replacing them every year. Thumbs Up
Post #374613 27th Nov 2014 4:13pm
