Home > Technical > Why do sidelight bulbs aways burn out in under a year? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20479 |
Used the most, always on.
Worth checking the voltage on them though. |
25th Nov 2014 5:42pm |
I got annoyed with it today too after replacing 3 or 4 this year so nipped over to bolt on bits and got a pair of their rdx led sidelights so I'm hoping for no more problems for a good long time.
Ray |
25th Nov 2014 6:01pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
Are you buying dodgy bulbs from the same place? 1953 80"
1987 mini city e 2011 90" |
25th Nov 2014 9:09pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Hmmm... I'd have to break out my multimeter thing and then figure out how to use it. I've had it for about 20 years and used it... once.
I usually buy the bulbs from Halfrauds. The seem to last about a year. |
26th Nov 2014 2:14pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
You really do need to upgrade to LED units...
A one off, plug and play replacement that will probably last longer than your truck... And they're reasonably priced now, but very effective... And saves you breaking out your MM... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
26th Nov 2014 2:24pm |
I'm very tempted. OK - now convinced.
Chris at CSK gave me some LED replacements for the dome lights (which seemed to have a lifespan similar to the sidelights) and they're quite bright and likely to last forever. LED is probably the way to go. Just replaced some halogen spots in the house with LEDs, much softer light and the room doesn't turn into a sauna. |
26th Nov 2014 2:27pm |
These are the ones I went for, they are brilliant, literally, and the Seller is ace...
Clicky > RDX LED Sidelight Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
26th Nov 2014 2:33pm |
What he said ^^^^
26th Nov 2014 2:57pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Is it just me ? I've never changed one in mine (4 1/2 yrs). 2005 Td5 90 XS
Steve |
26th Nov 2014 7:32pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Me neither 2002 110 td5
26th Nov 2014 10:18pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
5 years now and never replaced any exterior bulb - only 40K miles though, which probably helps.
27th Nov 2014 12:20am |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2760 |
I've done 70k miles/4.5 years and never changed a bulb!!
You can get heavy duty bulbs, seen them in halfords. Supposed to be more vibration resistant and last longer. No experience of them though. As above, voltage issue? Multiples per year sounds excessive unless you drive with side lights on all the time, in which case get some DRLs! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
27th Nov 2014 12:31am |
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 |
I've had the defender 11 years and only changed them all once, at about 9 years, because they were actually going black on the outside of the glass. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
27th Nov 2014 5:52am |
Thanks for the advice all... perhaps it has to do with where we live? We're up on top of a hill, it is always misty/damp here.
Anyway, will move to LEDs, enough of this replacing them every year. |
27th Nov 2014 4:13pm |
