Home > In Car Electronics > Nav
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Nav
Hi guys got a new defender coming next month any ideas how to mount a sat nav nice and tidy maybe like the svx also after help with what one is best
Thanks
Post #374217 25th Nov 2014 10:23pm
Have you considered Navi through a new HU? Appreciate that is the costly route though.
You can purchase the SVX mounting bracket for a Garmin navi but it's costly for a piece of plastic and I decided against it myself.
Main issue is the power supply, I've made my own with some custom wiring down the back so there is no lighter socket plugs in the way etc it's all hidden.
Post #374225 25th Nov 2014 11:10pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I bought the SVX bracket, cost a fortune and very tricky to track down at the time. There seems to be more stock of them now. I had to fabricate an aluminium backing plate for it to bolt up to otherwise the plastic dash is abit weedy. Perhaps that bit (as originally supplied with the SVX kit) is is now available as well?
I fed a lead through a hole in the dash, with hindsight, I would have fed the cable from behind the mount so it was less visbile when the tablet was not mounted.
Bodged up a garmin mount to the car dock for my tablet and got a decent sized sat nav that my ageing eyes can make out details on.
Mostly works fine, but in direct sunlight, the tablet refuses to charge anymore, claiming it is too warm, so might not make it all the way to the destination if I don't start with it fully charged.
Post #374228 25th Nov 2014 11:28pm
easydeluxe
Belgium 2008 Defender 90 Puma 2.4 HT Epsom Green
is there a part number for the svx bracket? Where to source?
And can you please measure the ball part? So I can check if my garmin montana cradle would fit?
thank you very much in advance!
Post #374240 26th Nov 2014 7:26am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
No need to measure. They fit. Wink
Post #374243 26th Nov 2014 7:40am
easydeluxe
thx!
Post #374244 26th Nov 2014 7:44am
I thought most the the more recent top end Garmin sat navs came with a mounting arm that also incorporated the power and a speaker. If you use the SVX arm you will not be able to benefit from these functions.
I would not want to advertise the fact that the sat nav may be sat in the cubby box with having a permanent mounting on the dash. Sucker mount to windscreen works very well.
Post #374257 26th Nov 2014 9:29am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
BRACKET, MOUNTING (3) Part number: LR018662
http://www.brit-car.co.uk/product.php/1606...et_def_07_
KIT - NAVIGATION SYSTEM (1) Part number: LR008217
http://www.brit-car.co.uk/product.php/1527...it_def_fl2
The ball part is "standard" garmin ball for nuvi series !
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #374279 26th Nov 2014 12:09pm
Theater
FITTING INSTRUCTION
Personal Travel Assistant
http://topix.landrover.jlrext.com/topix/co...oupId=1666 Marco
Post #374283 26th Nov 2014 12:25pm
