Home > Maintenance & Modifications > Stainless steel EGR blanking kits
Page 11 of 16 <123 ... 101112 ... 141516>
spudfan
Ireland
Got that, I was aware of this info. But my question still is, if you use a blanking plate with a smaller hole than the one it covers, will the smaller hole not clog quicker than the larger area it covers because you are forcing the same amont of stuff through it as used to go through the larger area?
I am not convinced of the efficacy of the EGR system per se in the diesel engine setup. Fair enough the emissions maybe be slightly cleaner than without it, but the fuel consumption is up. This seems a retrograde step. If you consider all the EGR engines doing less miles per gallon, that is a lot of fuel being burnt that could be used to get us all travelling further.
It is all very well to say that this new engine is more environmentally friendly owing to lower emissions but it is not very environmentally friendly to be burning more fuel. Maybe I am trying to square a circle but it does seem like common sense has gone out the window. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #37338 30th Jul 2010 9:23pm
K9F
The EGR valve recirculates 'particulate' airborne particles, the diameter of the smallest orifice of the blanks is 10mm therefore there is no danger whatsoever of it getting clogged! Read the thread the results speak for themselves and the original pictures posted show clearly how the blank works! It's down to personal choice, if you're not happy or your conscience is getting one over on you don't fit a blank! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #37344 31st Jul 2010 12:09am
Robofarmer
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Mad Cow wrote:
CapeLandy
It would appear that to date the only way anyone has found to fool the sensor is to leave a hole in the plate Very Happy
The alternative is to have the light on all the time.
There are ways and means of blanking the manifold side totaly and letting the egr valve have all the clean air it likes from a source which i have tryed but i have yet to make this 100% safe . (ie water and debris induction through the egr.. WORK IN PROGRESS Very Happy It certainly would great if someone could help with the electronics side of this problem Whistle Whistle (BAS and pete could be the answer) Egr valves are a curse Evil or Very Mad Evil or Very Mad on these puma engines in many ways and need doing away with!!! Thumbs Up Thumbs Up 2008 110 County utility
ex 1988 defender 90 ,td
ex 1970 series III
Post #37375 31st Jul 2010 7:11pm
dgardel
Italy
If can help ypu, I'm on project!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #37399 1st Aug 2010 1:03am
dgardel
Italy
IID Pro MV License
Post #37400 1st Aug 2010 1:03am
K9F
What both of you? Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #37409 1st Aug 2010 10:18am
Robofarmer
Hi dgardel i,m driving to italy the beginning of august about the 14th i should be there for a fortnight maybe we should meet up ? Thumbs Up 2008 110 County utility
ex 1970 series III
Post #37414 1st Aug 2010 11:38am
CapeLandy
South Africa
Speak of the Devil.
My EGR has started "hunting" when cold - can hear a chirping from the rear of the engine.
Also when shutting down after only a few minutes running the EGR cleaning cycle sounds like a bag of loose spanners
Post #37420 1st Aug 2010 4:27pm
kim-joshy
Australia
egr and particulate filters
hi has anyone replaced or gutted their particulate filter and fitted straight through exhausts ,,without management problems or how far have we got on egr remAVOL OR BLANKING
Post #37521 2nd Aug 2010 5:23pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
on second from smallest hole so 12 mm i think
seems ok there must be away to feed the egr nice clean air instead of the gases 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #37522 2nd Aug 2010 5:31pm
MK
just guessing: what about between the air filter and turbo? or throu a 2nd (and smaller) air filter? Shocked Puma 110" SW
Post #37523 2nd Aug 2010 5:42pm
big steve
i was thinking that or like a breather 2015 2.2 tdci hardtop xs
Post #37532 2nd Aug 2010 6:34pm
spudfan
Ireland
Been mulling this over too. Perhaps a system whereby you could temporarily stop the exhast gas feed and substitute it with a fresh air feed. This might be necessary if the vehicle had to go in for warranty work or it needed to be returned to factory spec. for m.o.t. purposes. If a tap or "T" piece could be fitted from the main air intake and a small hose fitted to that, this could be routed to the egr and another tap or "t" piece fitted to take this connection into the pipe taking the exhaust gases to the egr. The exhaust gas could be stopped above this "T" piece or vented depending on how best to fool the sensors. It sounds complicated but there has to be a way of substituting air for the exhaust gas. Look on it as a plumbing problem. Don't know how the sensors would handle the change. Is there a sensor that monitors the amount of exhaust gas being used before it hits the egr? I am sure given the right pieces og tubing someone will crack this. 1982 88" 2.25 diesel
Post #37534 2nd Aug 2010 7:12pm
Robofarmer
Here are a few pics so you can see were i am upto . The next bit is to pipe clean safe air to this void that can easly fitted and put back to original format for dealer vists!!.
This gap is all you are going to get leaving the egr bolted in the original position. I have tested this gap size for a while and it is enough. Just need to make it safe. Thumbs Up :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2008 110 County utility
ex 1970 series III
Post #37552 2nd Aug 2010 11:04pm
big steve
ok nice one robo is the light coming on though
i was thinking along those line but a machined peice about 10mm thick with a hole drilled with a union of to a breather or sonething ?
using a blanking plate to block the manifold
altho you would havt to only use th manifold bolts to hold the egr on without a supporting bolt im shure it wont hurt ?
steve
any one got down to the 10mm hole yet 2015 2.2 tdci hardtop xs
Post #37553 2nd Aug 2010 11:17pm
