Home > Puma (Tdci) > Why its never end? Appears that my turbi is gone
Eduardo
Hi guys
Sorry to bother you again with troubles but appear that my Defender have more gremlims than ussual Sad
2 days ago I notice oil in the steering protection bar and checking more carefully I found a oil exhudate in the area of the intercooler showed in this picture (borrowed from Internet)
Some pictures taken yesterday to illustrate:
I sent the pictures to my Indy and according to him, probably my turbo is leaking oil inside the intercooler Big Cry
The Defender have now almost 200,000 km. Turbo is working OK but according to him soon or later the oil will block the intercooler Sad and should be check soon.
Any other "less expensive" idea about what can be?
I feel a little bit down Sad Eduardo
Post #372725 19th Nov 2014 12:11pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Well....if it is oil from the turbo it means that your intercooler must have a leak/hole in it??? How els will it leak from your intercooler (which will be filled by oil by this time....) on to that cross member?
Does the Defender smoke a lot?
Disconnect your turbo to intercooler hose at the intercooler intake and see if there are massive amounts of oil there. Remember that there will always be a weee bit of oil vapour in your turbo hoses but it should not be "wet" with oil.
That is also right under the power steering reserviour and power steering box. Is there not a leak? (Not so sure about where what is on the LHD)
It is also in the general erea of the brake vacuum pump which is well known to leak. Maybe check that as well?
Post #372739 19th Nov 2014 1:44pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
If the turbo seal was gone,the smoke screen from your exaust would be "quite" visible from many hundred meters away!
Check the steering box very carefully,on a buddy's (LHD)puma,it doesn't leak from the usual seals (to steering column or steering arm),it leaks from the front side of the box exactly over this crossmember!
Generally oil vapour residues will be visible at the intercooler hoses as they age,no matter how tight the hose clamps are..
Clean the area and observe,no need to hurry..
EDIT
I'just show your steering box in these pics,it doesn't leak but check the steering pump hoses (not shown in the pic)
Post #372748 19th Nov 2014 2:24pm
Eduardo
Thanks a lot for the help
No visible smoke as far as I see Neutral Eduardo
Post #372768 19th Nov 2014 3:34pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Is the oil a reddish colour? It could be from the power steering reservoir hose. I found an oil patch in the same place and it turned out to be a loose hose clip. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #372807 19th Nov 2014 5:37pm
munch90
If the turbo is leaking oil in to the inlet side , its not the worry of oil blocking the intercooler its the fact that if the turbo leaks enough oil for the engine to start running on its own oil then it will start revving then higher and higher and you wont be able to stop it
YOU NEED TO GET THE TURBO CHECKED BECAUSE IF IT IS LEAKING OIL IN TO INLET SIDE AT SOMETIME YOUR ENGINE WILL GO BANG !!!!!
AND GET IT CHECKED SOON !!!
but I have seen lots of intercoolers with oil in the bottom corners on the outside and always thought its where the oil sits in the bottom and effects the rubber seal between the core and the end tank that lets a bit of oil out under pressure , nearly all intercoolers will have a little oil in the bottom [/b][/u]
Post #372844 19th Nov 2014 7:39pm
martinfiattech
As said some intercoolers sweat oil mist for years and run fine or the hose just lets a little oil thru.
Don`t forget check oil level, filters, hoses, breathers first. ect.
If you really want to check the turbo, drop off the induction pipe to the turbo and feel for play on the turbine shaft.
( the same as when checking a wheel bearing). There will be a small amount, have a look in side the at the impeller blades ? Are they all the same and not mushroomed at the edges. Does the turbo turn smooth, no tight spots. Pull the shaft it`s self in and out there should be no movement. There will be a small amount of oil in there. OF COURSE DO THIS WITH THE ENGINE OFF....
Then a test with the engine running, This may log a fault code, be warned. You will need an assistant.
Remove the induction pipe to the inlet manifold, get your self a piece of a4 white paper.
Start engine, and hold the pipe to the manifold give the engine a few revs to clear pipe, oil always gathers at the joint.
With your piece of paper held 8 inches or so from the pipe (turbo output to inlet manifold) Get your assistant to rev the engine to 2000 / 3000 rpm. If your sheet of white paper is now covered in black oil your turbo`s nackard.
If you have the odd spot of oil it`s more than lightly ok. There will always be some oil carried over.
This method checks the turbo under boost conditions ( granted not full boost but it`s a good indicator) Excuse the spelling I`am better with spanners and wires.
Post #372867 19th Nov 2014 8:53pm
munch90
Agree with above
Post #372869 19th Nov 2014 8:57pm
Eduardo
Thnaks guys for the prompt answers.
In fact, as I can see today, the oil sweets from the bottom part of the intercooler and the oil level remains the same than when was filled (4,000 km ago) . Anyway the Turbo will be check during next week to see if need to be changed or not.
Thanks again!
Bow down Bow down Bow down Eduardo
Post #372903 19th Nov 2014 10:31pm
Regard
Jeez...maybe also get your intercooler cleaned and ask them to pressure test it to see if there are any holes in the intercooler?
Post #372949 20th Nov 2014 7:33am
Fifth Horseman
Up to the introduction of the TDCi engine there used to be a 4 year/48k mile flush of the intercooler.
As noted, check the condition and tightness of the hoses first, at your milage it is probably worth flushing the intercooler anyway.
Post #372952 20th Nov 2014 8:43am
Eduardo
Well,
An update of this:
Turbine shaft with play due the seal wear, so the oil is getting through the intercooler that have a small crack.
The turbo will be replaced tomorrow and the intercooler will be repaired later on.
Quite expensive business Sad Eduardo
Post #375158 30th Nov 2014 2:34am
newhue
Australia
intercooler
I have an OE intercooler from my 2010 2.4 I am not using you can have. If you like I can post it to you. If your interested PM some details and I'll get a quote. In perfect order, removed from vehicle 12 months ago. To fit a larger much more expansive one with questionable results. My Defender and travels
Post #375627 1st Dec 2014 7:30pm
