Home > Maintenance & Modifications > Performance brake discs
Page 2 of 2 <12
Bomber82 wrote:
mse mine is a 110, different weight and different reaction in case of braking, but believe me, the OEM brake are not perfect at all....
Are the 90 and 110 brake the same because if they are i can see what your saying. Discs i doubt could be larger due to wheel size but what about braking pressure and pad compounds ect
Post #37250 28th Jul 2010 4:50pm
K9F
roel wrote:
It's not the braking power but more the controll off the braking power and tyres;
Roel hit the nail on the head as tyres also have a significant influence on braking capability. Upgrading of brakes doesn't appear to be a 'high frequence' modification, your terrain must be quite radical for an upgrade of brakes to be high on your list of priorities, or you must be carrying alot of weight one would surmise. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #37257 28th Jul 2010 5:07pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
What you say is right! Thumbs Up
Perhaps it would be to make a preliminary ...
Increasing the braking power is being to influence the kinematics of the vehicle, then play a key role not only tires but also the suspension, they increase the movement of cargo from front to rear, and lighten the rear of a vehicle like the 110 is not never a good thing!
You've never driven a 90 and a 110 on a snowy mountain road full of hairpin turns?
Well the different reactions that have vehicles in curves are similar to those under braking (without ABS ...)
That's why the first change I made was to mount four Scola shock with adjustable preload compression and rebound, custom-made for my 110.
In this way you can have a set-up like a go-kart to use every day, and you can soften it all if necessary.
With this solution I could get rid of the anti-roll bars to increase the off-road excursion.
Tire speech is important, the General Grabber series offer a good grip also on wet surfaces, the problem arises when I assemble the Kumho KL-71 but, as they say, you can not have your cake and eat it too ... Laughing
If the brake system of 90 and 110 are different I am not convinced, I do not have the "little cat" on hand to check ... Matteo
Defender 110 Td4 SE MY 09
Post #37285 29th Jul 2010 5:54am
Bomber82
So now I have last quotation:
Nitrac
16 groove front vented discs � 213.71
16 groove rear discs � 197.98
Shipping � 36.32
Total � 448.01 ( �370.06)
Tarox
G88 front vented discs � 256.05
G88 rear discs � 250.00
Shipping � 36.32
Total � 542.37 ( �449.36)
I discarded DBA discs because are too expensive, costs almost twice ....
I know Tarox very well, but I've never heard about Nitrac...
The price difference is not little, I can buy a full set of pads with it!!
About pads, Nitrac recommended EBC (because they sell it...), Greenstuff are good pads?? Matteo
Post #37570 3rd Aug 2010 8:38am
Porny
Site Sponsor
From past experience, I have never been that impressed with EBC green stuff pads or discs... well as a combined package. They seen to have a very narrow window when they work.. from cold they are no better than standard, as they warm up they get ok, but then they seem to back off again very quickly - i.e. back to brake fade when driven enthusiastically.
I also think DBA for example don't recommend the use of EBC pads with their discs.
If you wanted to go further than just a pad and disc change, I will soon be able to offer a 6 pot caliper and 346mm disc conversion for all Defenders. This will out perform any other kit avalaible, and for less money.
But you will need to run 18" wheels Wink
Ian
Post #38662 20th Aug 2010 1:11pm
Bomber82
I was thinking exactly as you Porny about EBC!!
I will choose the Ferodo or Brembo, Tarox are very good but too much expensive...
Unfortunately here in Italy we cannot mount 18" wheels.... Big Cry Matteo
Post #38671 20th Aug 2010 2:40pm
Porny
Site Sponsor
Shame you can't fit 18's... lol Whistle
With a big 6 pot caliper your Defender would stop very well!!
Ian
Post #38752 21st Aug 2010 3:56pm
Bomber82
The bigest tyre we are alowed to mount on Defender is 255/85/16....someone also 285 but is not so "official"... Rolling Eyes Matteo
Post #38774 21st Aug 2010 8:27pm
Page 2 of 2 <12
