Home > Maintenance & Modifications > Window blanks/covers |
jonny2tanx Member Since: 06 Jul 2014 Location: Harpenden, Herts Posts: 156 |
We drove to Belarus in the summer with a very fully loaded 110 and I just cut some mdf to slot behind the rear seats to blank out the glass, but more to prevent stuff breaking the glass and falling out on to the autobahn than to prevent prying eyes. Easy to slot in and remove. Rear windows are a bit more awkward but a piece of mdf across the car would serve a similar purpose. Total cost £0 as I had the wood in the shed. Constructed by Messrs Heath and Robinson
17th Nov 2014 9:22pm |
knrv8 Member Since: 30 Mar 2010 Location: Eastleigh Posts: 7 |
These might suit you - http://automarineimprovement.co.uk/camper-...l-screens/
18th Nov 2014 12:28pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1720 |
If it was me personally doing it Id do like on our boat.
As said cut some ply to shape covered in carpet and hold in with 2 toggles on the trim. That way you can take them out and put them under the rear mat when not in use. would look neat to Defender puma dormobile camper |
18th Nov 2014 12:50pm |
Stuarta Member Since: 11 Apr 2014 Location: Shrivenham Posts: 38 |
I like the thin ply idea and could spray/paint the reverse (window) side black to look 'tinted' from outside. Silvered material (like motorhome blinds) draws attention to the fact that there might be something in there!
18th Nov 2014 1:08pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
Have you thought of anything like this from B&Q the perforations are tiny it would also give the illuison that they were security grills.
http://www.diy.com/departments/steel-panel...326_BQ.prd perforated steel perforated panel |
18th Nov 2014 2:06pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 788 |
My 110 has pre-proper-utility blanked off windows- but I am guessing you are wanting a quickly interchangable option. Im planning on dropping a set of 88in van sides in instead.........
Chris |
18th Nov 2014 5:47pm |
