![]() | Home > Td5 > TD5 new radiator gauge on dash hardly moves, viscous fan? |
could be two things
1: engine will not get hot with the heater fan running , heater water is taken before thermostat , with engine doing no work just tick over then it wont make enough heat to get hot to show on a gauge leave it running without heater fan blowing , heater control on hot , only put fan on to check there is hot air as that shows water is being pushed round then turn fan off again , this way you should see movement on the gauge but doubt your get anywhere near running temp without engine under load or even if your driving gently with fan on full speed it may be enough to keep temp down , turn fan off and see if temp goes up to normal 2: thermostat stuck open ( if temps were ok and doing wot its ment to do before then should be ok ) if temp before was pretty steady as in not rising and falling between moving and stationary , if it went up and down change thermostat if the thermostat is doing what its ment too, it doesn't matter if you got a rad a mile wide it will get up to temp , the stat is really a control valve it should open only enough to allow enough water though to keep engine at running temp |
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 ![]() ![]() ![]() |
ok will try option 1 as i've always had the heaters on low or medium on hot as it's so cold at the moment
will try at idle and when driving temps before where fine no movement in gauge needle it always sat at just below 1/2 once warm only thing i've not checked is the pipes by the thermostat if they are getting hot both sides of it, but i guess it would've blown a pipe by now is the stat wasn't opening? all other pipes are fine the top pipe with the bleed screw is hard to touch once engine is run up and i can squeeze this a little and its nice and hot |
still no joy tbh ran without heaters on for 10 miles and then done a spirited drive for another 5miles and the gauge went ever so slightly higher, put the heaters on and it was warm but no where near nice and toasty warm.
checked all the pipes they are all hot and can touch them fine no pressure in the system, both sides of thermostat fine as well and can touch them without it burning my hands so going to order a new thermostat as i guess it has stuck open |
Sounds like an airlock to me. Take the radiator cap off let the engine get up to temp slowly then open the screw in vents till water comes out and retighten then rev for 5 mins or so (all with the heaters off) then put the cap back on and see if it's any better.
