Home > Puma (Tdci) > 2.2 Defender 90 height |
666PXX Member Since: 05 Mar 2014 Location: Berkhamsted Posts: 113 |
Hi, full details on page 50 of the below
http://www.landrover.com/content/gb/en/pdf/ebrochures/defender That said, I had the same problem - lowered mine with the 2" kit to get it to fit only to find that the kit actually lowers it 1.5" at the back. A few pounds later I purchased a air compressor to lower the tyres to get it in and then pump it up when it's in! All good fun |
17th Nov 2014 9:48pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Hi Just been out to measure for you.
2M dead on |
17th Nov 2014 9:52pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Jay you are a true gent thank you!!!
666 how tall was your garage door? |
17th Nov 2014 9:57pm |
Gus Member Since: 10 Nov 2014 Location: Perth Posts: 17 |
Just for a bit of variety, mine measures 2.02 at the highest point (rear edge of roofline).
This was the clincher for buying the new 90 as I'd previously been looking at 110's which measured 2.06 at the back and the entrance to our car port is 2.04. Will have to pay close attention to tyre pressures and new tyre selection. |
18th Nov 2014 4:13am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
this appears to be a common problem, at my last house I had an up and over door and still had 3-4 inches clear above the roof, this house with side hinged garage doors I had to remove the door stays from the frame and still only have about 1/2 inch clearance between door frame and roof, it was a consideration when moving but I measured both to be sure it would (just) fit DEFENDER 90 TDCI XS,
18th Nov 2014 5:19am |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Just in case it helps, my 110 Hard Top (described in the official blurb as 2027mm high) was 2064mm high when delivered. To get it into the garage (with a door aperture 2034mm high), I had to let the back tyres down until they were almost flat. I'm glad I've got a compressor.
18th Nov 2014 6:37am |
Joe - that's a relatively huge difference what wheel/tyre combo you running and have you checked the colour coding of the springs to see they've fitted the right ones?
Made a mental note to go check mine and see how accurate the brochure was. |
18th Nov 2014 9:34am |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 |
Same problem here...
Only recently resolved with electric roller doors rather than conventional up-&-over; to gain any proper height I'd first need to remove the garage lintel for which I was quoted £400 per door. Consequently, I now have 19cm gap above the rain gutter as on my 90 HT, I found that the back door wasn't my highist point due to a slightly sloping drive HTH TT "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
18th Nov 2014 10:50am |
I'm on the standard 5.5J steels and 7.50 x 16" Michelins. There was plenty of clearance with the tyres let down to about 5psi. I've no idea about the springs, but as I only wanted to get the van into the garage once to rust proof it and sort out proper mudflaps and wheel arch liners, I'm not too bothered about whether it will fit in easily again (and now with its roof bars on, there's no chance anyway). |
18th Nov 2014 8:55pm |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Your wheel/tyre selection will make a difference to the overall height.
18th Nov 2014 10:59pm |
2014 Station Wagon on HD steel wheels and Goodyear MTR's coming in at around 2015mm (or 79 1/4").
19th Nov 2014 8:59pm |
In the MY14 brochure the height for all models is just quoted as 2,000mm - 2,182mm (78.7-86) with the comment "Vehicle height depends on tyre and suspension options".
20th Nov 2014 9:22am |
