Home > Puma (Tdci) > 2.2 Defender 90 height
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
Strange request but does anyone who has a new 2.2 90 (ideally hard top although I'm sure they're the same as a csw) mind measuring the height from the floor to the roof above the tail door (that's the highest point) and posting it here? Would be a massive help as possibly about to hit a huge garage dilemma!
Many thanks
Post #372306 17th Nov 2014 10:25pm
666PXX
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Hi, full details on page 50 of the below
http://www.landrover.com/content/gb/en/pdf/ebrochures/defender
That said, I had the same problem - lowered mine with the 2" kit to get it to fit only to find that the kit actually lowers it 1.5" at the back. A few pounds later I purchased a air compressor to lower the tyres to get it in and then pump it up when it's in!
All good fun
Wink Wink
Post #372324 17th Nov 2014 10:48pm
JAY BOY
Wales
Hi Just been out to measure for you.
2M dead on
Thumbs Up
Post #372329 17th Nov 2014 10:52pm
bga86
Jay you are a true gent thank you!!!
666 how tall was your garage door?
Post #372331 17th Nov 2014 10:57pm
Gus
Australia 2014 Defender 90 Puma 2.2 SW Fuji White
Just for a bit of variety, mine measures 2.02 at the highest point (rear edge of roofline).
This was the clincher for buying the new 90 as I'd previously been looking at 110's which measured 2.06 at the back and the entrance to our car port is 2.04.
Will have to pay close attention to tyre pressures and new tyre selection. Smile
Post #372373 18th Nov 2014 5:13am
LR90XS2011
this appears to be a common problem, at my last house I had an up and over door and still had 3-4 inches clear above the roof, this house with side hinged garage doors I had to remove the door stays from the frame and still only have about 1/2 inch clearance between door frame and roof, it was a consideration when moving but I measured both to be sure it would (just) fit DEFENDER 90 TDCI XS,
Post #372376 18th Nov 2014 6:19am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Just in case it helps, my 110 Hard Top (described in the official blurb as 2027mm high) was 2064mm high when delivered. To get it into the garage (with a door aperture 2034mm high), I had to let the back tyres down until they were almost flat. I'm glad I've got a compressor.
Post #372383 18th Nov 2014 7:37am
Joe - that's a relatively huge difference what wheel/tyre combo you running and have you checked the colour coding of the springs to see they've fitted the right ones?
Made a mental note to go check mine and see how accurate the brochure was.
Post #372427 18th Nov 2014 10:34am
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Same problem here...
Only recently resolved with electric roller doors rather than conventional up-&-over; to gain any proper height I'd first need to remove the garage lintel for which I was quoted £400 per door.
Consequently, I now have 19cm gap above the rain gutter as on my 90 HT, I found that the back door wasn't my highist point due to a slightly sloping drive Shocked
HTH
TT "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #372443 18th Nov 2014 11:50am
Joe the Plumber
Made a mental note to go and check mine and see how accurate the brochure was.
I'm on the standard 5.5J steels and 7.50 x 16" Michelins. There was plenty of clearance with the tyres let down to about 5psi.
I've no idea about the springs, but as I only wanted to get the van into the garage once to rust proof it and sort out proper mudflaps and wheel arch liners, I'm not too bothered about whether it will fit in easily again (and now with its roof bars on, there's no chance anyway).
Post #372568 18th Nov 2014 9:55pm
Cuthbert
Your wheel/tyre selection will make a difference to the overall height.
Post #372617 18th Nov 2014 11:59pm
Cuthbert
2014 Station Wagon on HD steel wheels and Goodyear MTR's coming in at around 2015mm (or 79 1/4").
Post #372871 19th Nov 2014 9:59pm
In the MY14 brochure the height for all models is just quoted as 2,000mm - 2,182mm (78.7-86) with the comment "Vehicle height depends on tyre and suspension options".
Post #372958 20th Nov 2014 10:22am
