![]() | Home > Technical > Magmount CB Aerial on Puma Bonnet |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Can't see why that shouldn't work well or how about a gutter mount for the aerial ? 2005 Td5 90 XS
Steve |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Out of curiosity ... May I ask why you need to fit a CB ?
I made a bracket that bolts to the top rear door hinge, no drilling and is nice and high up .. I can send a photo if you want
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 619 ![]() ![]() ![]() |
The CB is for off roading, taking the p1££ when someone gets stuck etc.
Steve, photo would be great thanks..
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 ![]() ![]() ![]() |
http://www.cbradio.co.uk/cb-accessories/mounts-and-bases.html "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows." |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
I use this one I also place a little bit of rubber over the screws so as not to damage the paint. Cable passes through the door top without damage the beauty of this clamp is that the aerial is high up and out of the way and with a spring mounted aerial it works a treat
http://www.4x4cb.com/public/page.cfm?CatID=786 ![]() ![]() |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I have never liked that gutter mount since one ground a groove in my Range Rover.
This is the one I have mounted on the 110. http://www.thunderpole.co.uk/fixed-body-mo...t-kit.html Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
there you go ... behind the bolts are a couple of spacers to keep the angle off the hinge, the cable runs thru the door... the lower mounting is widened to allow adjustment
Note the quick release antenna base you could have it, it's in the garage somewhere but can't find it, even though i've been clearing it out ![]() ![]() Click image to enlarge |
