Home > Technical > Magmount CB Aerial on Puma Bonnet
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I need to put my CB into the truck, but as yet cannot reconcile myself to drill holes in my new pride and joy!!!
Would a magmount aerial on the bonnet work as the bonnet is steel?
I have done lots of googling but cannot see any puma with an aerial mounted this way, but from what I can tell you get a good ground plane from a bonnet.
Post #372073 16th Nov 2014 9:10pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Can't see why that shouldn't work well or how about a gutter mount for the aerial ? 2005 Td5 90 XS
Steve
Post #372076 16th Nov 2014 9:17pm
Anderzander
Out of curiosity ... May I ask why you need to fit a CB ?
Post #372096 16th Nov 2014 11:08pm
I made a bracket that bolts to the top rear door hinge, no drilling and is nice and high up .. I can send a photo if you want
Post #372114 17th Nov 2014 6:51am
dnorrishill
The CB is for off roading, taking the p1££ when someone gets stuck etc.
Post #372167 17th Nov 2014 1:14pm
dnorrishill
Steve, photo would be great thanks..
Post #372168 17th Nov 2014 1:14pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
http://www.cbradio.co.uk/cb-accessories/mounts-and-bases.html "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #372189 17th Nov 2014 3:27pm
gilarion
I use this one I also place a little bit of rubber over the screws so as not to damage the paint. Cable passes through the door top without damage the beauty of this clamp is that the aerial is high up and out of the way and with a spring mounted aerial it works a treat
http://www.4x4cb.com/public/page.cfm?CatID=786
Post #372200 17th Nov 2014 4:14pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have never liked that gutter mount since one ground a groove in my Range Rover.
This is the one I have mounted on the 110. http://www.thunderpole.co.uk/fixed-body-mo...t-kit.html Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #372216 17th Nov 2014 5:26pm
there you go ... behind the bolts are a couple of spacers to keep the angle off the hinge, the cable runs thru the door... the lower mounting is widened to allow adjustment
Note the quick release antenna base
you could have it, it's in the garage somewhere but can't find it, even though i've been clearing it out Wink
Post #372267 17th Nov 2014 8:02pm
