Home > Td5 > TD5 fuel pressure regulator hose refit into cylinder head |
HI welcome
I used one these I.e. brake pipe nut spanner |
16th Nov 2014 1:09pm |
Branny Member Since: 16 Nov 2014 Location: Morzine Posts: 9 |
Hi Dorsetsmith. Thanks. Just took the angle grinder to a deep socket only to find that its still too restricted to get in! Spanner, meet angle grinder. Assume that you did this from the top and that it was not easy...
16th Nov 2014 2:23pm |
its not an easy job
16th Nov 2014 2:30pm |
Any more info on this would be gratefully received. One modified 14mm spanner later, I could just about mount it, but there is then not enough space turn it! Jow the heck is this thing installed initially?!
16th Nov 2014 3:57pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1620 |
Would say it's fitted with the manifold off in the first instance.
17th Nov 2014 12:13am |
