Home > Maintenance & Modifications > Fitted Wheel spacers, now got the colly wobbles
Mother superior
Gents
Just fitted some 30mm spacers, and now have the dreaded 50/60 MPH wobble so I'm off to get the wheels balanced.
My question is: should I try and get the wheels balanced with the spacers still fitted ? ...I'll mark everything up so it all goes back the same way when I nail it all back together .
Seems to me that this would "Balance" the spacers as well .
Wes Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #371864 15th Nov 2014 10:14pm
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Did you clean the hub faces and torque up the spacers or just do them up tight? I had an independent landy mechanic do mine and he was ultra careful fitting them and ive had no probs at all. Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #371869 15th Nov 2014 10:41pm
Mother superior
Hello Mate
Eeerrrrmmmm.. With regard to the torque setting I sort of gave them a "good horsing" up with a breaker bar
Any idea of the correct setting?
Wes Oh woe, oh woe
It will not go.
Post #371871 15th Nov 2014 10:46pm
redzob
No sorry. Left it to my local expert. Hopefully someone here will know? Defender Puma 2.2 XS 90
Vespa GTS 300
Post #371873 15th Nov 2014 10:49pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Hi mate
I've got them on mine and no problems
Are your ones the ones that locate the wheels ?
Are they sitting on straight to the spacer ?
Might be worth whipping them off and reseating 👍 It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #371875 15th Nov 2014 10:53pm
munch90
Yes make sure mating surfaces are clean and flat , but also if you have any play in top or bottom swivel joint or track rod end it will show up more with spacers and could give you wobble
I used spacers on my old defender for years and never had any problem , but I have always used 2 steering dampers anyway
Post #371877 15th Nov 2014 11:08pm
mk1collector
I'd only ever buy hub centric spacers and always tighten them in a star pattern to the specified 130nm and check the tightness of the spacers at about 100 miles after initial fitting then refit the wheels then check the wheel nuts torque 100 miles later. It might be ott but I'd rather be safe than sorry.
Post #371885 15th Nov 2014 11:52pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
How'd you find that set-up? And how have you got it mounted if you dont mind me asking?
Post #371888 16th Nov 2014 12:18am
munch90
leave the standard one as it is , but fit one on the bar behind the axle mounted of the diff , as there its more direct acting as its dead inline with the bar
Post #371897 16th Nov 2014 9:15am
galvernisednuts
England 1994 Defender 110 300 Tdi SW Santorini Black
My old 90 td5 ran with spacers and had a wheel wobble about 55 to 60 mph and you could accelerate through it and it disappeared
Got the wheels balanced and that sorted it
I'm a big fan of spacers and my Landy covered 60 k with them on and the wheel bearings gave no issues, I checked em every 6 months when greasing props etc between servicing
Post #371906 16th Nov 2014 10:33am
galvernisednuts
I would check the condition of your tyres for any uneven wear/stepped edges
Also check for bearing and swivel play
If the problem persists it's worth a look at the damper too, I've disconnected them for a test run to see if they changed the issue, obviously be careful as there'll be no damping effect whist doing this
Post #371909 16th Nov 2014 10:37am
I've tried a couple of sets of spacers; I love the look of them, but both sets gave me drastic wobbles.
They were both non-concentric type. I think the ones with the inner centralising "ring" are the better ones to go for.
Post #371983 16th Nov 2014 3:22pm
Terryt
Always check the wheel sits against the spacer .....
Terry
Post #371995 16th Nov 2014 4:36pm
K9F
Dynamic balancing beads will sort it out if you find nothing obvious and can't get the wheels balanced on the truck itself.
http://www.defender2.net/forum/topic29747....=balancing
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #371997 16th Nov 2014 4:51pm
Mo Murphy
How old is your vehicle ? Are you using alloys ?
50 Shades of Pennine Grey
Post #372033 16th Nov 2014 7:39pm
