![]() | Home > Td5 > Intercooler fan |
If it's got ac then I might be the aircon fan - standard electric fan in front of aircon rad / intercooler / rad
Do you have a picture ? Are you experiencing this with the ac off ? |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
Yes, it's got A/C. The fan stays on at all times, even with A/C off.
I'll post a picture once I get a chance |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
Sounds more like you've got an AC problem and that is causing fan to continually run.
Pull the AC fuse and see if it stops. Andy |
So it defiantly shouldn't be running with the A/C off? Hmm must be a sensor or switch issue.
No. Although I believe if the engine temp is very high the ECU can activate the fan to assist with cooling, but normally only on when AC switched on.
Hard to think of the engine ever getting hot... Gets warm, but hot is on the wish list.
I'll try pulling the A/C fuse and see what we get. |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
You'll find you have a logged fault for a temperature sensor. Clear it and all will return to normal
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
landyandy is spot on about the AC fan running as part of the EMS overheating strategy on Defenders fitted with A/C. Have you carried out any diagnostic checks? I would be curious to know what the readings/live data are from the CHT sensor?
Going to take it in on Monday and plug it in.
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I believe the A/C fan should normally cut in when the ambient temperature is above 28 degrees C ( not very often in the uk). I hope someone hasn't wired the fan to run continuously to disguise an engine temperature issue ! 2005 Td5 90 XS
Steve |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
A/C fan si controled by the TD5 engine ECU. I was written here - check engine ECU for faults. When TD5 engine goes over temperature it started the A/C fan and will start it again every time engine is running.
With Nanocom you can also test the fan - it can energize it for a short time. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
An overheating fault or a faulty sensor will cause the A/C Dan to run constantly. Clear the fault and/or replace the sensor should cure the issue. It wasn't me!
I've had this happen several times in the past with flat batteries or a jump start causing the temp sensor fault. Clear it and all returns to normal
