Home > Puma (Tdci) > Where is this nut from?
Alicat
I had a rattle in the rear of the 90. On further investigation this nut fell out. It came from the bottom of the trim that surrounds the rear side windows.
Any idea as to what it should be holding together?
Thanks
Tony
Post #371763 15th Nov 2014 12:13pm
steve E
Wales
I found the exact same nut in my 2013 my 110 a few weeks into ownership and still have it in the cubby box Laughing
I too would love to know where it came from.
nothing has fallen off yet.
Post #371766 15th Nov 2014 12:36pm
smb
It looks like one of the nuts that hold the side panels onto the tub. When I took all the trim off mine I found that half the bolts didn't have nuts on and two had loose nuts. It was quite worrying to have found the only thing keeping the body on mine was probably the weight of the roofrack Shocked
Post #371773 15th Nov 2014 12:57pm
Alicat
Hmmmm, I suspected it might be something like that!
I won't started taking the trim off yet to check the others.
Thanks
Tony
Post #371781 15th Nov 2014 2:08pm
Pickles
Had the exact same nut, found in exactly the same place, & I put a post up about it.
Dealer had a look, put some sort of torch/mirror along the inside of that plastic trim & said everything looked ok.
I've had no more rattles, nothing is vibrating or appears to be loose etc, so I'm not too concerned. Others have had similar items found in various locations around their Defender!
Pickles.
Post #371861 15th Nov 2014 9:03pm
richardg
2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Found the same nut when took off the rubber cap where the old style jack used to fit on the chassis at the front end.
Post #371866 15th Nov 2014 9:27pm
keith
Here is the very nut fallen from its home behind the plastic window surround panel . It's not from the panel but from the body capping from the tub to hardtop . Only solution is to locktight it on as it always comes off , there are more of them .
Post #371928 16th Nov 2014 10:30am
It is, as others have said, from the bolt that secures the side panels to the tub.
One of these on my demonstrator dropped off as I pulled away from the supplying dealer on the day I collected it Rolling Eyes
We often find them loose when removing the trim to leather.
Post #371933 16th Nov 2014 10:42am
Alicat
Cheers Keith, that is exactly where mine dropped out from.
Tony
Post #372005 16th Nov 2014 4:50pm
