Home > Maintenance & Modifications > Any tips on installing LIGHTFORCE 240s?
sookoon
United States
I'll be getting in a pair of LIGHTFORCE 240s (one HID, one regular), and a pair of 140s (both regular). The 240s would go inside the protection bar, and it looks like it will just barely clear the winch. Any tips from those who have installed these? Graphic below would indicate rough positioning... Thanks gentlemen!
Post #371609 14th Nov 2014 12:48pm
Gareth
I have 240's inside the A bar. They do just fit.
You do need to cut out the grill behind to sit them back flush with the front of the A bar. I reckon they look pretty neat. Cool
If you don't cut the grill, they will stick out forward of the A bar. Mine has the Aircon fitted, so may have less room than a non aircon vehicle. Its easy to cut the grill, I just attacked it with a large pair of cutters!
 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #371617 14th Nov 2014 1:45pm
sookoon
United States
That looks really marvelous.
That looks really marvelous. Just what I had envisioned.
Post #371639 14th Nov 2014 6:06pm
K9F
I think you'll be hard pushed to fit them flush with a winch. Take the centre portion of the grille out first and offer them up. If they don't fit alternatively you could possibly get some brackets made to 'pick up' on the top mounting holes of the a-bar brackets themselves which would offer you more room and not have to commit to cutting perhaps? The brackets unlike mine which return back on themselves could be simply a flat plate to keep the lights raised clear of the winch, I did something similar with my 240s. Ask Gareth to measure the distances between the lowest point of the light and the bumper and the depth of the light to the grille perhaps to get a better idea. It'll be damn tight I reckon. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #371643 14th Nov 2014 6:27pm
Gareth
I'll do just that tomorrow, and take some more pictures, I reckon you are right though, a winch will make it a squeeze. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #371716 15th Nov 2014 12:17am
K9F
Gareth,
I seriously doubt they will fit with a flush fit scenario. Mine are f*in HUGE and I didn't wish to cut my KBX Premium Grille. The measurements would give a 'snaphot' if the concept would work with a winch.
Thumbs Up Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #371724 15th Nov 2014 1:35am
sookoon
United States
I'll provide an update with play-by-play pictures
in about ten days (the time it takes for DHL to get form UK to CL.
Post #371725 15th Nov 2014 1:38am
Gareth
Measurements.
From the bottom edge of my spotlight to the top face of standard bumper = 14cm
From top edge of spotlight to bottom face of A bar = 3cm
Protrusion into grill (through home made cut-out) = 5cm. This makes them sit flush with front face of A bar.
You could extend the distance between bottom of lamp and bumper by making some custom brackets. Max possible would be 17cm.
Post #372154 17th Nov 2014 1:10pm
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
If you didn't have an A bar what would you sudgest? 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #372162 17th Nov 2014 1:55pm
K9F
^^^Buy an A-Bar or a lightbar or buy some lamps that can be mounted to the bumper.
Lorryman100 wrote:
I fitted this small A bar from Terrafirma and the light bar sits snugly underneath. Now contemplating fitting another, Spot only light bar on top of the A bar??
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #372220 17th Nov 2014 6:31pm
sookoon
United States
It turns out that I didn't need to go flush, since the winch protrudes another four inches past the front of the brush bar. Here's an image.
Post #377179 8th Dec 2014 12:27am
MK
Although no longer fit there as they do restrict airflow. Puma 110" SW
Post #377924 10th Dec 2014 9:40pm
Eduardo
As per MK said,
During summers and under loading, the ligths there will restrict the airflow to the radiator producing a undesirable engine overheating.
Cheers Eduardo
Post #378074 11th Dec 2014 11:18am
sookoon
United States
I finally got the 240's installed.
Post #435664 4th Jul 2015 3:33am
K9F
Nice fit and like the colour of the lenses too. Thumbs Up
I had to have some new brackets made for mine after some tealeaf decided to have a go at removing my lights and bending the aluminium ones. Got some cut and bent.....3mm stainless.
Post #435704 4th Jul 2015 10:00am
