Home > Maintenance & Modifications > Loose steering column cowling |
epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395 |
Screws to the column so perhaps a screw is missing
13th Nov 2014 4:24pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17480 |
IIRC the cowl screws at least partly to a metal plate which forms part of the indicator switch assembly. Is the indicator switch loose as well?
If not, then I suspect that the most likely reason is that one or more screw is not fully home or is cross-threaded. The cowl should not be loose, and although it probably won't do any harm I would still be inclined to try to find out why it is. |
13th Nov 2014 4:33pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20500 |
I think I'll investigate, nothing else is loose (inc the indicator switch assy)
Just the cowling its self. |
13th Nov 2014 4:54pm |
Or it's been over tightened and broken the thin bit of plastic that the screw head sits against
13th Nov 2014 5:04pm |
Could be, I haven't tightened it myself or the previous owner but of course I can't guarantee it.
I'd imagine it's been left since the factory. |
13th Nov 2014 5:33pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5744 |
Could be like mine where the screw underneath is tight but the plastic around it is broken and I believe that is the only fixing that aligns it the rest of the fixings are just to join the two halves.
Andy |
13th Nov 2014 6:01pm |
I wouldn't be surprised if a replacement costs a fortune no doubt.
13th Nov 2014 6:04pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
I can get mine to either look as if it is put together right but is loose, OR is tight but one side is badly fitted together. I can always get all but one screw in whatever order I put them in. Its a Defender eccentricity manifestation thing I thinK!!! There is nothing broken though, so it might be worth playing about with
13th Nov 2014 7:07pm |
