Home > Maintenance & Modifications > Windscreen washer pump |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
Have you check that the non return value is working correctly? Mine didn't allow more than a dribble through. Fixed by drilling it out so no longer a value
10th Nov 2014 12:52pm |
I haven't checked it but I will now is it behind the dash or in the engine bay?
Cheers Ray |
10th Nov 2014 1:00pm |
Passenger side - engine bay near the bulkhead.
It looks like it's just joining the two pipes together. |
10th Nov 2014 1:04pm |
I've just been and bought a pipe joiner so I'll give it a go.
Cheers Ray |
10th Nov 2014 2:00pm |
My Discovery was the same I just removed the NRV in total and it worked much better than before. If you go through life with your head in the sand....all people will see is an ar5e!!
10th Nov 2014 5:25pm |
not the valve on mine. I've been reading round the net and a few mentions of disco 2 headlight washer pumps have come up but no confirmation they work so I've ordered one to give it a go.
10th Nov 2014 5:28pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
I'm sure there was a thread on here a while ago about this and I'm pretty sure that the rear washer pump is more powerful than the the front one (they have different part numbers). 2005 Td5 90 XS
Steve |
10th Nov 2014 9:37pm |
I did a search on here but didn't find that one. I tryed swapping them over today and it didn't make much difference aswell as getting rid of the nrv which did nothing so I'm going to try a headlight washer pump when it arrives.
10th Nov 2014 10:23pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
I'm using a red top rear washer pump for my twin washer set up with no trouble at all
11th Nov 2014 3:28pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 501 |
When it arrives, you'll find that the D2 headlamp washer pump uses a larger sealed connector than the Defender's windscreen washer pump.
If the D2 pump physically fits your washer bottle, I can help with the connector required for the D2 pump, or a short adaptor harness from the Defender's harness to the D2 pump. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
11th Nov 2014 3:29pm |
I might be intouch with you about the connector for the d2 pump any idea on price?
11th Nov 2014 4:12pm |
The D2's headlamp washer pump connector is the same as used on each half of the D2's heated windscreen -
Click image to enlarge The connector to mate with the Defender's washer pump connector, is this - Click image to enlarge If the D2 pump fits the Defender's washer bottle, and delivers the volume/pressure you want - then, the only issue that I can see is that the Defender's wiring isn't heavy enough to supply the D2 pump. On the Puma, the front washer pump wiring is in 0.5mm˛ cable. On the D2, the headlamp washer pump is wired in 1.5mm˛ cable, and fused at 20A. The proper way to wire it would be to have the Defender wiring switch a relay powered from its own 20A fuse, which switches the D2 pump on heavy gauge wiring. . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
11th Nov 2014 7:42pm |
Alex2000 Member Since: 23 Mar 2020 Location: North Yorkshire Posts: 9 |
where can i get that connector?
24th Feb 2023 6:48pm |
Hi
i have a optimill washer pump i think its the same as a D2 and a rover 45 washer pump and i am wanting to know what type of connector they use as i dont have a connector for the optmill one as i got on its own |
24th Feb 2023 7:47pm |
