Home > Maintenance & Modifications > Windscreen washer pump
mk1collector
Having fitted the twin windscreen washer mod to my defender the pressure of the water coming out has dropped Big Cry this could be down to it being an old motor and replacement could solve the problem but I wondered if anyone knew if the rear screen washer pump was more powerfull as it has to pump the water further? It has a different part number to the front so if it's stronger I may just fit two of them. Alternatively does anyone know of a better pump that's an easy fit?
Ray
Post #370771 10th Nov 2014 12:46pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Have you check that the non return value is working correctly? Mine didn't allow more than a dribble through. Fixed by drilling it out so no longer a value Smile
Post #370772 10th Nov 2014 12:52pm
mk1collector
I haven't checked it but I will now Thumbs Up is it behind the dash or in the engine bay?
Ray
Post #370775 10th Nov 2014 1:00pm
Paddie42
Passenger side - engine bay near the bulkhead.
It looks like it's just joining the two pipes together.
Post #370778 10th Nov 2014 1:04pm
mk1collector
Thumbs Up I've just been and bought a pipe joiner so I'll give it a go.
Ray
Post #370791 10th Nov 2014 2:00pm
K9F
My Discovery was the same I just removed the NRV in total and it worked much better than before. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #370826 10th Nov 2014 5:25pm
mk1collector
Big Cry not the valve on mine. I've been reading round the net and a few mentions of disco 2 headlight washer pumps have come up but no confirmation they work so I've ordered one to give it a go.
Post #370828 10th Nov 2014 5:28pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I'm sure there was a thread on here a while ago about this and I'm pretty sure that the rear washer pump is more powerful than the the front one (they have different part numbers). 2005 Td5 90 XS
Steve
Post #370923 10th Nov 2014 9:37pm
mk1collector
I did a search on here but didn't find that one. I tryed swapping them over today and it didn't make much difference aswell as getting rid of the nrv which did nothing so I'm going to try a headlight washer pump when it arrives.
Post #370944 10th Nov 2014 10:23pm
Mo Murphy
I'm using a red top rear washer pump for my twin washer set up with no trouble at all Very Happy
50 Shades of Pennine Grey
Post #371049 11th Nov 2014 3:28pm
PaulMc
When it arrives, you'll find that the D2 headlamp washer pump uses a larger sealed connector than the Defender's windscreen washer pump.
If the D2 pump physically fits your washer bottle, I can help with the connector required for the D2 pump, or a short adaptor harness from the Defender's harness to the D2 pump.
. Paul.
Post #371050 11th Nov 2014 3:29pm
mk1collector
I might be intouch with you about the connector for the d2 pump Thumbs Up any idea on price?
Post #371055 11th Nov 2014 4:12pm
PaulMc
The D2's headlamp washer pump connector is the same as used on each half of the D2's heated windscreen -
The connector to mate with the Defender's washer pump connector, is this -
If the D2 pump fits the Defender's washer bottle, and delivers the volume/pressure you want - then, the only issue that I can see is that the Defender's wiring isn't heavy enough to supply the D2 pump.
On the Puma, the front washer pump wiring is in 0.5mm˛ cable.
On the D2, the headlamp washer pump is wired in 1.5mm˛ cable, and fused at 20A.
The proper way to wire it would be to have the Defender wiring switch a relay powered from its own 20A fuse, which switches the D2 pump on heavy gauge wiring.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #371112 11th Nov 2014 7:42pm
Alex2000
where can i get that connector?
Post #983565 24th Feb 2023 6:48pm
Alex2000
Hi
i have a optimill washer pump i think its the same as a D2 and a rover 45 washer pump and i am wanting to know what type of connector they use as i dont have a connector for the optmill one as i got on its own
Post #983571 24th Feb 2023 7:47pm
