Home > Td5 > Flywheel and clutch: Valeo or Luk |
Carlosbeldia Member Since: 13 Oct 2013 Location: Cartagena Posts: 43 |
Right now I have a brand new Valeo clutch and flywheel set, and have traveling to Colombia a Luk set. Some experience on Luk one? I have used Valeo, but the flywheel is kind of weak (this is the third flywheel of this car, whit 250.000 km), was wondering if maybe the Luk one could be an improve. Thanks for your comments.
10th Nov 2014 6:17pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
I bought a luk one and when I opened the box it was a valeo. Might not all be the same though? 2002 90 Td5 Station Wagon
10th Nov 2014 10:30pm |
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 |
Valeo was fitted from new was it not by LR?
11th Nov 2014 11:34am |
I thought it was a luk flywheel from factory
11th Nov 2014 12:46pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Valeo was OEM. LUK are good to, but for the TD5, they may just be reboxed Valeo's.
My one in a 54 TD5 is Valeo, date stamped 2004. |
12th Nov 2014 11:42am |
Thanks a lot for your comments. I'm going to ask to the commercial people to be sure if they are Luk or just Valeo reboxed (I work in Luk). Let you know any news...
17th Nov 2014 5:15pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1620 |
LuK are part of the Schaeffler group and are a quality brand not a cheap aftermarket brand FAG, INA and Ruville are all part of the group and the biggest flywheel manufacturer in
Europe so I wouldn't have any concerns, I would fit a matched set (clutch and flywheel, release bearing, spigot bearing) I would be looking at the nose cone (that the release bearing rides along) and checking the output shaft is true as maybe someone before has had the weight of the box hanging on it. There is also a plastic cup in the clutch fork that the fork pivots the pivots on check this for wear it is widely missed. Do not use grease except on the splines or this can happen (see attached pic) http://www.schaeffler.com/remotemedien/med...140814.pdf Click image to enlarge Click image to enlarge |
17th Nov 2014 11:10pm |
Thanks a lot Nick. That was a really big wear in that tube...
19th Nov 2014 3:14pm |
