Home > Td5 > Flywheel and clutch: Valeo or Luk
Carlosbeldia
Columbia 2001 Defender 110 Td5 SW Epsom Green
Right now I have a brand new Valeo clutch and flywheel set, and have traveling to Colombia a Luk set. Some experience on Luk one? I have used Valeo, but the flywheel is kind of weak (this is the third flywheel of this car, whit 250.000 km), was wondering if maybe the Luk one could be an improve. Thanks for your comments.
Post #370842 10th Nov 2014 7:17pm
grafty99
I bought a luk one and when I opened the box it was a valeo. Might not all be the same though? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #370946 10th Nov 2014 11:30pm
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
Valeo was fitted from new was it not by LR?
Post #371017 11th Nov 2014 12:34pm
mk1collector
I thought it was a luk flywheel from factory
Post #371027 11th Nov 2014 1:46pm
silky16v
just removed my flywheel from my TD5 last night as i was replacing it and it was Valeo with date stamp 08/01 so the original item i presume
Post #371237 12th Nov 2014 11:32am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Valeo was OEM. LUK are good to, but for the TD5, they may just be reboxed Valeo's.
My one in a 54 TD5 is Valeo, date stamped 2004.
Post #371246 12th Nov 2014 12:42pm
Carlosbeldia
Thanks a lot for your comments. I'm going to ask to the commercial people to be sure if they are Luk or just Valeo reboxed (I work in Luk). Let you know any news...
Post #372212 17th Nov 2014 6:15pm
NickMc
LuK are part of the Schaeffler group and are a quality brand not a cheap aftermarket brand FAG, INA and Ruville are all part of the group and the biggest flywheel manufacturer in
Europe so I wouldn't have any concerns, I would fit a matched set (clutch and flywheel, release bearing, spigot bearing)
I would be looking at the nose cone (that the release bearing rides along) and checking the output shaft is true as maybe someone before has had the weight of the box hanging on it. There is also a plastic cup in the clutch fork that the fork pivots the pivots on check this for wear it is widely missed.
Do not use grease except on the splines or this can happen (see attached pic)
http://www.schaeffler.com/remotemedien/med...140814.pdf
Post #372361 18th Nov 2014 12:10am
Carlosbeldia
Thanks a lot Nick. That was a really big wear in that tube...
Post #372758 19th Nov 2014 4:14pm
