Home > Puma (Tdci) > Oil filter smashed off
stevie
Bit of bad luck. Whilst slow moving up a woodland track a log has flicked up under the defender and totally destroyed the oil filter assembly. Oil light came on and I switched the engine off straight away, so hopefully engine is ok. Had to get recoverd to the nearest road then recovery has taken it to the dealers for inspection.
Post #370584 9th Nov 2014 4:34pm
munch90
not that uncommon on the late transits for filter damage , just replaced a transit engine for same thing driver touched a kerb and holed filter needed engine and turbo replaced ( courier driver just kept driving , still drove when it came in just knocking badly ) , engine was only 12 weeks old in it anyway fitted under warrentry because of the problems with the later oil pumps on the 2.2 tdci
don't think I would have wanted it taken to a dealers , they will charge for replacing filter housing and guess any warrentry will be gone now they seen that or will advise new engine
Post #370587 9th Nov 2014 4:54pm
K9F
Three years ago after getting the stainless steel intercooler grilles made I proposed an oil filter protector.....
Apparently.......
BigMike wrote:
Bearing in mind its position, it would be pretty odd to get an impact on it, so on that basis, not sure why it needs a guard.
Question Whistle
There are things already available at a price....
http://www.entreq.de/protection-gear/schut...uhler.html
http://www.extreme4x4.co.uk/acatalog/TRANSMISSION_GUARDS.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #370591 9th Nov 2014 4:58pm
munch90
Post #370594 9th Nov 2014 5:04pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
[quote="K9F"]Three years ago after getting the stainless steel intercooler grilles made I proposed an oil filter protector.....
Jesus was that really 3 years ago! Time flies, mine still looks like new!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #370614 9th Nov 2014 6:37pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Apparently.......
Question Whistle
The Entreq one looks nice and apart from the price looks good, however it looks like its retained by the anti roll bar bolts.... I'd hate to have to pull that off every time I change an oil filter.
Jonno
Post #370715 10th Nov 2014 7:03am
I have the entreq guard fitted, when I fitted the guard I also fitted a diff lock drain plug... Had a big service on Friday and it did not need to be removed Thumbs Up
Post #370716 10th Nov 2014 7:07am
Where does this figure on the Entreq one?
Post #370761 10th Nov 2014 12:06pm
They are the fuel lines
If you look at the product on the entreq website, move your mouse over the top left of the photo .. Additional photos are displayed
Post #370824 10th Nov 2014 5:24pm
stevie
All fixed and everything ok. No issues with warranty either. Now after a guard that covers the oil filter. Just guna look at the one above.
Post #371110 11th Nov 2014 7:33pm
