Home > Puma (Tdci) > Syncro
mse
Syncro
What would be the indication of a dodgy syncromesh on the gear box...now my clutch is finally right, im trying to work out if this is how its supposed to be or a problem masked for 2yrs by dodgy clutch(es) Mike
Post #36818 23rd Jul 2010 3:41pm
MK
I beleive even in last generation gearboxes 2nd gear is still a bit rough. My new gearbox is quiater in 6th than the old one.
About 2-3% on Moly should fix the 2nd gear. Remember that syncros need a bit of friction to work properly and it is one of the reasons to use GL-4 oil spec. Puma 110" SW
Post #36819 23rd Jul 2010 3:50pm
mse
I was planning when the warranty ends, to change all the fluids to the diff lock version - had success with them in previous land rovers + im not too confident on the long service intervals with the standard oil Mike
Post #36830 23rd Jul 2010 6:29pm
MK
Actually these oils (factory) are full synthetic Puma 110" SW
Post #36833 23rd Jul 2010 6:39pm
mse
I guessed they were - i think they have been for some time.
My problem is last time i checked, the components (transfer and diffs) are almost the same as those you would once change oils every 12k now i think its every 40k!
Gearbox is an unknown, so i like the idea of changing the oil to see if it improves it Mike
Post #36834 23rd Jul 2010 6:42pm
MK
gearbox is any synth 75W-90 GL-4 Puma 110" SW
Post #36840 23rd Jul 2010 7:32pm
bob neville
Mike
One of the problems my new clutches are supposed to have sorted is the syncro, or lack of.
The only gear that I have a real problem with after the latest clutch is second, which has always been the main offender. My dealer has adjusted the detents etc. but still it is impossible to engage smoothly.
I have found that after using diff lock and low range for a while I do get a slight improvement.
Guess it is something I can live with, especially after the last clutch change saga.
Bob
Post #37038 26th Jul 2010 11:20am
MK
i have a brand new gbox and it is better than the old one but still a bit rough . Dgardel added CPL additive stuff and he managed to have it smooth. Puma 110" SW
Post #37040 26th Jul 2010 11:32am
bob neville
Anybody got any idea of what Dgardel added and how much - I have tried a search and not found the answer - yet !
Bob
Post #37041 26th Jul 2010 11:43am
MK
http://www.defender2.net/forum/topic2139.html?highlight=cpl Puma 110" SW
Post #37042 26th Jul 2010 11:46am
bob neville
Thanks MK - I just found it as well Thumbs Up
Also on this post.
http://www.defender2.net/forum/post19142.html#19142
CPL gearbox additive, 125 CC.
Bob
Post #37043 26th Jul 2010 11:53am
mse
If your slow with the changes it really does help - by slow i mean not to snatch at the change.
May try the gearbox additive.
Mine i dont think is that bad/has a problem - just wanted to get ducks in a line Mike
Post #37045 26th Jul 2010 12:16pm
bob neville
Mike
My change from first to second has to be so slow I am almost stationary by the time I engage second !
Also, attempting to change to second at above 10mph is a lottery !
I am tring to find a UK dealer for CPL at the moment - it has got to be worth a try.
Bob
Post #37046 26th Jul 2010 12:21pm
mse
Mine isnt like that - although it could be how i change gear differently to you anyway?
Do halfords not sell it - they sell the others. Mike
Post #37048 26th Jul 2010 12:23pm
bob neville
Halfords don't sell it. Only places I have found so far are in Germany or CPL in Italy - not sure if they will sell directly.
My temporary solution works fine if I am not towing something - I don't bother with first gear Laughing
Bob
Post #37054 26th Jul 2010 12:54pm
