Home > Puma (Tdci) > Syncro
Page 2 of 2 <12
MK
If you have a Liqui Moly dealer you can use Ceratec (about 150 ml). It is was developed for engines, but also can be used on gears as the spec sheet states. LM is a serious brand. Puma 110" SW
Post #37055 26th Jul 2010 1:07pm
mse
But first is a good gear!
Why not try one of the other fluids? there are plenty and all similar
Maybe its unipart i have seen it in... Mike
Post #37057 26th Jul 2010 1:20pm
bob neville
Had a very interesting telephone conversation with Castrol technical support about not being able to buy BOT 130M, the recommended gearbox oil, and what would be the best equivalent.
I will not bore you with all the details but BOT 130M is not generally available and can only be purchased via LR dealers (under LR part number) and Castrol strongly recommend that it is the only one of their oils that should be used in 2007 onwards defender gearboxes.
My plan is to follow Dgardel's route, drain the box, refill with some additives and see how I get on.
Bob
Post #37217 28th Jul 2010 12:51pm
mse
Bob
What worries me - is if its not easily avaliable - then i cant see any other garage stocking it...especially for you...or caring! So if you pay someone, anyone to service it who are not a)Contentious and b)Fully understanding of LR, what the new oils etc - your screwed and there is no way of knowing Exclamation Mike
Post #37233 28th Jul 2010 3:36pm
bob neville
Totally agree Mike.
The guy at Castrol said that it is ONLY available through LR now.
He did say that there are alternatives but he would not recommend them especially for a 2009 model.
Maybe there was a change in gearbox spec / oil spec in 2009.
Bob
Post #37235 28th Jul 2010 3:45pm
mse
bob neville wrote:
Totally agree Mike.
Bob
Possibly - the easy way to check would be consult a manual - mine is an 08MY Im not sure if it had its oil changed when it had its first clutch, so could/should be the original oil - which may or maynot be a bad thing hearing what people experience with the later ones and gear changes!!
I shall have a look at the electronic version now Mike
Post #37237 28th Jul 2010 3:51pm
mse
From the
Publication Part No. LRL 10 02 51 702, Copyright 2007 save 5/2008
Main gearbox oil Castrol BOT 130M Mike
Post #37239 28th Jul 2010 3:53pm
bob neville
That's what my handbook states as well.
Bob
Post #37241 28th Jul 2010 4:02pm
mse
Oh the possible joy... Mike
Post #37243 28th Jul 2010 4:03pm
fekete
doesn't Opie Oils supply this ? or could point you in the right direction NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #37259 28th Jul 2010 5:14pm
MK
You can use any 75W-90 GL-4 mineral or synth. Or GL-4 and GL-5 if it is synth as the EP additives do not corrode any "yellow" metal. Puma 110" SW
Post #37271 28th Jul 2010 8:08pm
dgardel
Italy
But BOT130M is discontinued and out of stock and Castrol give to the Land Rover Dealers the NEW BOT 328....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #37277 28th Jul 2010 9:26pm
dgardel
Italy
http://www.defender2.net/forum/post19142.html#19142 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #37278 28th Jul 2010 9:27pm
Page 2 of 2 <12
