Home > Puma (Tdci) > Blue Smoke
RobKeay
Blue Smoke
I have blue smoke coming out on start up. If you get out to have a look it puffs away till you rev it. Then the tickover seems lumpy.
Its a 110 with 2500 miles onit. Its only started doing it in the last 500miles and is getting worse. Ive been running it in and not thrashing it.
Hopefully someone knows whats causes this and can get the dealer to fix it. The trouble is I dont want to take in untill I have an idea what is causing it.
Post #36987 25th Jul 2010 4:38pm
MK
rule say: is oil going thru the valves, but before you take any action I suggest you check the oil level until the next service. Puma 110" SW
Post #36993 25th Jul 2010 5:46pm
dgardel
Italy
or turbo.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #37013 25th Jul 2010 10:09pm
RobKeay
This blue smoke seems to be only on start up. Sounds like it has a miss fire. Think I might video it to show the dealer. Guess turbo would be an easy swap.
Post #37022 25th Jul 2010 11:07pm
Grockle
are you waiting until the glow plug light has gone out before starting 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #37030 26th Jul 2010 9:35am
Personally i always do this. Would this be what could happen?
Post #37031 26th Jul 2010 9:43am
Grockle
yes unburnt fuel 2.4 90 XS
Post #37032 26th Jul 2010 10:14am
RobKeay
Yes I have even tried putting glow plugs on twice doesnt have any affect on amount of smoke. I am also in the habit of waiting for glow plugs as I have only owned diesel landrovers.
I take this isnt a common problem then!
Post #37103 26th Jul 2010 11:26pm
RobKeay
Would I know if the glow plugs are broke?
Post #37105 26th Jul 2010 11:28pm
MK
I would have it in observation for a while to check if the oil level drops. Also check you have the right oil dipstick.
if you are keen on dismantling you could look if there is oil at the intake air hose after the turbo or intercooler. Puma 110" SW
Post #37106 26th Jul 2010 11:32pm
RobKeay
Checking oil in hose i can manage that. But how do I know if its the right dipstick???
Post #37107 26th Jul 2010 11:37pm
YORKSHIRELAD
How do RobKeay. Mine was doing exactly what yours is doing. Lots of smoke on start up and then shaking about, missfiring. When it warmed up it was fine. It turned out it was a software update that had not installed correctly. Rolling Eyes . It didn't make any sense to me but it has been fine{touch wood} ever since.
Richard 1963 Series 2A truck cab
2008 110 SW
Post #37111 27th Jul 2010 6:35am
RobKeay
Nice one ill take it in and get it checke for updates!! Thanks for that I knew someone else would have the problem as well.
Post #37159 27th Jul 2010 7:09pm
RobKeay
Well its all fixed. Software problem!!!! Theres no smoke and the engine is sound now.
Post #38062 13th Aug 2010 7:35pm
Grockle
Thumbs Up 2.4 90 XS
Post #38066 13th Aug 2010 8:29pm
