Home > Technical > Rough idle when cold
AndrewS
Started the 110 this morning and boy was she ticking over rough. Good job I shut the drivers door otherwise Id have ended up sat on the pavement. Shocked It cleared after about 30 seconds. Going to start wearing a sports bra from now on Whistle
Post #3691 8th Sep 2008 5:42pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Andrew mine does the same . Very rough when started from cold but once it warms up sounds fine again. I find if I dont use too much throttle for initial 5 mins or so the coarse rattle is not so obvious. Have noticed it is getting progressively worse, so will have to get booked in to the dealers again !!!
Post #3695 9th Sep 2008 7:32am
AndrewS
Well mine is going in tomorrow for the following issues
Rear prop to transfer box bolts keep coming loose
New sump
Clunky back lash type noise in transfer box
Water running down the carpet each side of the transmission tunnel (I suspect a blocked drain in the heater/AC)
Chatter from gearbox when under load
Post #3697 9th Sep 2008 7:38am
Tim_NZ
Australia
New sump
Have you been driving my 110??? Smile I'm having all the above issues apart from the water leak. My 110 has started surging in 5th and 6th occasionally and is logging P0404 (EGR Fault) code Sad
Tim
Post #3702 9th Sep 2008 9:53am
Eduardo
Andrew
I have a list of 13 items that has been repaired or are under repair now that includes much of them.
In fact, the car have visiting the dealer at least 1 per month (now is there!) Crying or Very sad
But still I love it ... keep me busy Mr. Green
Maybe will be a good idea to keep an statistic of the failures to be aware.
Regards Eduardo
Post #3709 9th Sep 2008 2:01pm
jst
Andrew so is that to do with the latest engine replacement solution for here?
http://www.defender2.net/forum/topic472.html Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3716 9th Sep 2008 6:23pm
AndrewS
I will find out today Thumbs Up
Post #3735 10th Sep 2008 7:00am
sib
Hi Andrew S
Would be very intereted to hear what your dealership thinks the "transmission chatter under load" is as I have that with my 130. They`ve looked and done something to clutch but still same problem, so much be gearbox/propshaft related..
sib Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #3751 10th Sep 2008 7:26pm
Nidge
Andrew any news on your Defender yet ?
Mine is at the dealers now and I have been told it needs a complete new engine Crying or Very sad
Wont see it for a couple of weeks. Very inconvenient ! What concerns me now is how much experience does my local dealer have of installing a new Puma engine !!
Hope you have better luck with yours.
N.
Post #3910 17th Sep 2008 11:05am
AndrewS
Sib it was the rear prop bolts again Neutral They have now been replaced.
Nidge Got the car back now and have been told to monitor it Shocked
Post #3911 17th Sep 2008 11:10am
AndrewS
Should change the title to rough idle whenever, anyway changed dealer. The new dealer has found that the up dated software was saying it had loaded but actually hadn't, it took 4 goes to finally get the software load. They then carried out a re-learn of the pump and injectors. Finally after over 12 months the car idles like a puring pussy as opposed to a rattlesnake on crack. 130's have feeling's as well you know Smile
Post #64154 17th Mar 2011 10:01pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Same problem here. Main dealer/vehicle supplier failed to update injector software correctly, took it to another main dealer who identified the fault and updated the software correctly. Some dealers here seem to have issues with their computer systems and this is causing some problems.
Post #64273 18th Mar 2011 3:20pm
AndrewS
Spent the morning driving the car, WOW its like new a dream to drive Thumbs Up 130's have feeling's as well you know Smile
Post #64276 18th Mar 2011 3:31pm
bell-auto-services
I've been told today of another car that didn't have the pilot correction set and drove badly. This car had only 5 miles on it and was direct from the factory Sad
After it was done which in the end was a full download and update all was fine.
It just does go to show even the factory are having problems.
Pete
Post #64326 19th Mar 2011 3:20am
