Home > Td5 > misfire at idle
Turbotcharged
misfire at idle
Have recently bought an 04 TD5 70K miles...starts no problems...seems to go fine...(much better since I got the wheels balanced) just lately the fuel pump has raised its whine from wasp in a tin can to mosquito...not affecting starting or performance ( max speed comfortable speed is 70 ish) however I have noticed that if I freewheeel down my track (500 mts) the motor starts to missfire at idle......it picks up fine when I jab the throttle.
Am I paranoid and its just really all ok ?
Post #369769 5th Nov 2014 5:29pm
mk1collector
Check oil level for diesel in the oil as it might be injector seals and washers going.
Post #369778 5th Nov 2014 6:35pm
bob neville
Oil in the ECU loom could cause the miss fire as well as the crank sensor but most likely the first if it is not under power.
2013 Defender 90 CSW - sold
Post #369779 5th Nov 2014 6:45pm
Turbotcharged
Checked oil level..a tad high but no smell of diesel..possible overfil by previous owner...have got the spannerist changing the fuel filter and checking the fuel system before I get round to the injectors....it does not make the high whine when cold and on start up...it fires up instantly ..just when she gets warm...pitch increases..wondering if its air in system ?
Post #369809 5th Nov 2014 8:14pm
mk1collector
One of the common places fro getting air in the fuel system is injector seals and washers. Cheap to do aswell.
Post #369814 5th Nov 2014 8:23pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
Before you do anything just try putting a decent injector cleaner into the tank and run it. I had similar symptoms a few months ago on my 2004 Td5 so changed filter, checked FPR etc., and was about to go to town on the injectors but thought I'd give the cleaner a go. Worked straight away. Has run very sweetly since. You never know, no harm in trying.
Post #369831 5th Nov 2014 9:01pm
landy andy
If you are talking about a very slight misfire, when going from speed to idle suddenly, then I think it's normal for Td5's to do this. Mine did and it got to 167 thou miles before I sold it. Any body else noticed this? It did it in standard form and with two different tuners maps on it.
Andy
Post #369848 5th Nov 2014 9:32pm
JWL
Mine does this when I have been driving steadily and stop at a red light, the engine will run rough at tickover when I'm at a standstill. It can be improved on mine by fitting a new MAF sensor and then gradually comes back as the sensor becomes dirty again.
Post #369855 5th Nov 2014 10:09pm
Turbotcharged
Have purchased the seals (genuine most expensive bits of copper on earth)...am going to try some injector cleaner too befor I fit them..you nevewr know...the thing was undriveable over 50 ..was thinking polybush kit...suspension packages...blah blah...had the wheels balanced...different vehicle! Got to say though seals appear to be heading for a change.
Post #369869 5th Nov 2014 11:02pm
landy andy
Rubber seals as well as the copper ones?
It won't be the injector seals, as when they fail they allow air to travel backward through the fuel system, which can't happen whilst it's running. Failed injector seals give poor starting, and noisy pump before running problems.
Andy
Post #369873 5th Nov 2014 11:16pm
Turbotcharged
I hope it is not the seals...Pump has begun to whine at higher decibel level than normal....it primes ok..she starts on the button gets rough ish at the high end of rev range (70-75mph) ...but never had a TD5 defender before (Disco 1 300TDI) so might be normal and I am used to quiet cabins..hence the fuel filter ..The sound when she is cold from the pump is 'normal' ....once we get going and warm..pump sounds like its increasing in revoloutions...higher pitched tone...no loss of power...so seals must be suspect? Motor has only done 70K
Thanks for all the suggestions BTW much appreciated
Post #369874 5th Nov 2014 11:29pm
landy andy
Just checking before you do job that you've got five copper washer and five rubber o rings Thumbs Up
Andy
Post #369876 5th Nov 2014 11:33pm
Turbotcharged
Yes full kit of genuine seals...
Post #370003 6th Nov 2014 9:02pm
Turbotcharged
on the subject of Seals..my wife runs a diving business...can get a full set of salty seals if required!
Post #370320 8th Nov 2014 11:40am
Turbotcharged
Injector cleaner ??????
Filled up the tank put in some o dat cleaner...and...its gone quiet ??????
I think its the fuel level more than the cleaner???
Post #370644 9th Nov 2014 8:16pm
