![]() | Home > Td5 > Warming up period |
Big yes for the air heaters, my Eberspacher was in action this morning. Flicked it on 10 minutes before taking the boy to school and had clear windows and a warm motor. I then had to switch it off 10 minutes into the journey as the engine heater was working well by then.
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 ![]() ![]() ![]() |
The ones I've taken a quick look at so far are £800.00
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
A cheaper alternative is a Kenlowe hot start, this is a mains powered coolant heater and pump,I once had one in a previous defender and ran it off of a timer so the engine was pre warmed when I got in the car in the morning, the down side is that it is no use if you're away from base. 2005 Td5 90 XS
Steve |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1442 ![]() ![]() ![]() |
Find an extra jumper does the trick !!
![]() All part of the healthy lifestyle, think of the calories your shivering away ![]() |
Anyone fitted a water heater like some vauxhalls or renaults have that fits in the heater pipe and use diesel glow plugs in water , seems could be easy to do
Insulated the heater box, bubble radiator foil stuff and camping mat, the water pipes 28mm pipe insulation(it was almost a perfect fit), to and from the engine,10mm foam draft excluders down each wing,10mm latex backed felt glued to the bonnet.It made a noticable difference,I notice hea.....warmth coming thru the vents after a mile or so. Tbh,It warms up pretty much as quick as any car I've had,but it also stays warm whilst you go shopping, I've also closed off the cab behind the drivers seat with radiator foil stuff covering the dog guard,which is about the best thing you can do. Interestingly,the engine doesn't warm up noticeably quicker on the hottest of summer days either. I wouldn't want my air intake coming from the engine bay in case of any exhaust/fuel leaks. This is my auxiliary "pre-start" heater,lol,gets rid of all ice,moisture in less than 5 minutes,ftw ![]() Just flick the switch in the hall before I go out. ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8232 ![]() ![]() ![]() |
i fitted a webasto thermo Top C to my td5, loved it, well worth the money.
did the same to the tdci and added an airtop to it too! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
Diesel heater with remote control under the cubby box and electrical heater under the dash
![]() ![]() Click image to enlarge |
Plenty of things to think about and Improve then!
Im I right in thinking that there are 3 stages to this heating system. 1, A pre radiator and pre heater matrix water circuit, that is water that gets pumped around the engine block only The engine being the only method of heating this water. 2, water that gets pumped around the heater matrix when heat is selected. 3, and the water that when the thermostat opens, let's the cooling water flow though the radiator. Keith 2005 TD5 90 CSW XS |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
I've been looking at Webasto Thermo top c heaters and found this site;
http://www.carheaters.eu/ Has anyone had any dealings with them? I know that they are registered in Poland, but appear to be based in Cheltenham. Thanx in advance |
Buy an XS, it's got heated seats and windscreen.
