![]() | Home > Td5 > Warming up period |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
When I first bought my Td5 I thought it was slow to warm up (about 10 mins or so) and the gauge never made it to half way so I fitted a new genuine parts thermostat which made no difference at all ! I think others will confirm that the Td5 seems to be over cooled and the gauge bears little resemblance to the actual engine temperature. The gauge appears to have three readings, cold, normal, and too late ! 2005 Td5 90 XS
Steve |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
About right
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 ![]() ![]() ![]() |
Going to have to try something it's not even cold yet outside yet was like driving something out of the seventies ![]() |
Got both and I'm still ![]() ![]() ![]() |
I have had thoughts about improving the heater in my Td5 but tend to forget about it all summer ! Have thought about lagging the heater box itself to prevent it being cooled by the blast of cold air coming in between the bonnet and wing and have looked at the feasibility of blocking off the fresh air intake and rigging up a piece of trunking to take warm air from the rear of the radiator possibly making a hole in the shroud to connect it to, to have pre heated air going into the heater box. 2005 Td5 90 XS
Steve |
Some fit a muff on the front. If your running a larger inter cooler though it sort of defeats the object
![]() Cardboard would improve things ![]() ![]() Though a better option would be thin hardboard |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
you measure the warm up time of a TD5 in days not minutes!
It's not just mine then
Or a Webasto air top
![]() Steve |
A little OTT
My Dads old merc had something similar to that a couple of electric coils that heated the incoming air until the coolant warmed up, you could see them if you looked down the heater inlet in the scuttle, was quite alarmed first time I saw them ! 2005 Td5 90 XS
Steve |
There you go, let's track them down and look into fitting them, what a mod
muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 395 ![]() ![]() ![]() |
I'm glad I'm not the only one who's smug with a Webasto in winter ![]() |
What one have you got? 2005 TD5 90 CSW XS
