Home > Maintenance & Modifications > Installing a 12V plug in the back of a 110SW? |
Yes one of the 20A see the owner manual Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
24th Jul 2010 10:34am |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206 |
Thanks for the help ,all sorted now.
24th Jul 2010 4:00pm |
Markh Member Since: 24 Jul 2010 Location: Grantham Posts: 33 |
Installed 12v plug to rear of my 110 Puma today. Not an expert electrician but was suprisingly easy
As a novice hardest part was removing speaker panel without destroying plastic securing screws... (managed to break one of the three) Bought a female 12v plug, crimped on spade connectors to it and connected to T block hiding behind the panel "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..." |
24th Jul 2010 9:08pm |
