Home > Maintenance & Modifications > Fitting Chequer Plate?
Page 2 of 2 <12
mse
Froogle-Yorkshireman wrote:
Thanks for the reply to my post Bob.
Any chance you can snap me a picture so I can show my dealer.
How long ago did you have yours fitted?
You can see it in this pic (a little old) but note it sits flush
 Mike
Post #36752 22nd Jul 2010 4:12pm
2010 Defender 110 Puma 2.4 USW Stornoway Grey
Thanks Mike,
Is your CP land rover original and dealer fitted?
Simon
Post #36754 22nd Jul 2010 4:29pm
bob neville
Fitted in 2009.
Post #36756 22nd Jul 2010 5:30pm
Brilliant Bob - Thanks for snapping the pics - much appreciated! Sorry if you got caught in the rain.
The black CP looks great against the green on your defender.
When I went to check on the truck today at the stealers the sales guy tried to convince me that the CP came with the gasket sat 1/4" proud. I told him that it wasn't right so he was going to talk to the workshop. So frustrating as it's already on and if they have to remove it, trim the gasket and then refit the CP who knows what other sins they could cover up.
Looks like my local stealers are cow boys doesn't it or at best dumb wits.
I feel a bit like rejecting the vehicle and starting again with another dealer.....
Post #36758 22nd Jul 2010 6:10pm
bob neville
I can't imagine how they can think that is correct - I have seen the OE kit before fitting and I am sure the gasket is the same size as the plate - could be wrong though.
Just missed the rain - thunderstorms here at the moment.
If you want a good dealer if you decide to reject try Yeovil LR, mention my name and your vehicle will be a hell of a mess when you collect it .... only joking -great bunch of people Thumbs Up
Bob
Post #36760 22nd Jul 2010 6:19pm
Cheers Very Happy
Post #36761 22nd Jul 2010 6:27pm
leeds
Have been told, but not checked that the chequer plate wing tops for a Puma is narrower then for a 90/110.
Gaskets are readily available for the wing tops. We apply waxoyl prior to using stainless nuts and bolts.
HTH
Brendan
Post #36767 22nd Jul 2010 7:09pm
What's the general consensus on whether the plates can be removed and then refitted without detriment to the body work?
Post #36768 22nd Jul 2010 7:28pm
bob neville
Should not be a problem as they use rivnuts on OE - or should do.
I have removed my CP under the doors and that all went back OK.
Probably all that will need replacing is the gasket.
Bob
Post #36769 22nd Jul 2010 7:40pm
mse
Thanks Mike,
Simon
Mine is original fitted from new - i will add that bob's covers are not fitted correctly either - the plactic vents should sit above the checker plate - ive never see it the other way round before.
The puma plate technically is shorter - although i have the proper length that was made to fit by the dealer! the shorter version looks silly in my opinion - its because the bonnet is wider Mike
Post #36772 22nd Jul 2010 8:04pm
bob neville
Thanks Mike,
Simon
Never worked out how they did that Mike - both my vehicles were done that way !
I actually like the 'incorrect' fitting Thumbs Up
Bob
Post #36773 22nd Jul 2010 8:08pm
mse
Each to their own Thumbs Up thats what land rover ownership is just about all about Mr. Green
Dont know how easy it will be if you need to remove them for something, access snorkel fitting Whistle Mike
Post #36786 22nd Jul 2010 10:49pm
Page 2 of 2 <12
