Home > Puma (Tdci) > 2.2 Puma Kangaroo
LandyBen82
United Kingdom 2012 Defender 90 Puma 2.2 HT Firenze Red
2.2 Puma Kangaroo
I just wanted to know if anybody else suffers from a lower rpm (1250 - 1750 ish) kangarooing in 1st and second gear. The only way to stop it when it starts is give it more revs.
Any ideas on how to help reduce this problem......
Thanks - Ben
Post #367440 27th Oct 2014 9:36am
K9F
No cure, unfortunately you'll have to either live with it or adjust driving style to suit.....Do a search under 'rev hang.' Thumbs Up
One of the links.....
http://www.defender2.net/forum/topic20992.html?highlight=rev+hang If you go through life with your head in the sand....all people will see is an ar5e!!
Post #367446 27th Oct 2014 10:20am
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
My 2.4 used to do it sometimes. The airbox mod seems to have eliminated it. http://defender90xs.blogspot.co.uk/
Post #367448 27th Oct 2014 10:32am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
mine used to do it, there is a new software fix for it from dealers. Had it done last week, made a huge difference.
Post #367449 27th Oct 2014 10:39am
I've noticed that it can often be EGR instigated, just my observation of when that starts playing up and how it behaves.
I tend to where possibles especially in very cold weather let it idle for a few minutes before setting off.
Post #367462 27th Oct 2014 11:33am
Venomator
Is this fix just for 2.2 engines Nicks, or across the board for Pumas?... Question
Would you have the software fix reference for the upgrade please?... Thumbs Up
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #367474 27th Oct 2014 12:11pm
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Mine also does it just as you described. as I am sure you have discovered can be embarrassing during low speed manoeuvres, only cure seems to be slapping the clutch pedal just as it starts and feeding back out; tiresome, however, dealer couldn't help. I am sure I read somewhere on here that a side benefit of a remap was no more Kangarooing; little drastic! Not heard of Nicks software fix so would appreciate it if you (Nicks) could let us know what happened eg did you go to the dealer about the problem, did he call you to say there has been a recall or how did you get to know about it. Thanks
Post #367476 27th Oct 2014 12:13pm
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I also suffer from this (MY2014 90sx) and would be really interested to know more about the software upgrade? I've learned to live with it but still very annoying. Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #367501 27th Oct 2014 1:45pm
Hanechdene
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I suffer from this on MY15.
Have sent it back to the dealer only to be told that it should do this Shocked
Post #367571 27th Oct 2014 6:37pm
LandyBen82
I have a remap, intercooler and the latest ecu flash...... and still the same.
It almost seems like play in the drivetrain springing back and forth at slower speed. If that makes sense?
Post #367585 27th Oct 2014 7:24pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Mine (2014 110 van) occasionally does it slightly, usually only when starting off from cold, but I've not thought it worth going back to the dealer for (so far...).
Post #367591 27th Oct 2014 7:41pm
bob neville
Who did the map ?
I have a BAS map on my 2013 90 and it solved the kangaroo issue.
When you say you have had the latest ECU flash was it done after the Map ? If so, the ECU flash will wipe the map from what I have been told.
2013 Defender 90 CSW - sold
Post #367592 27th Oct 2014 7:42pm
LandyBen82
BAS Map & had the latest ecu flash when the intercooler was fitted.
I will be changing the drive flanges this week as there is loads of play in them! I hope this may reduce the kangarooing a little??
Post #367603 27th Oct 2014 7:56pm
bell-auto-services
The last flash Landrover made was only applicable to the 2012 cars to bring them inline with the 2013/4 cars.
Their has been no new updates now for over a year that change the torque delivery action of the throttle pedal at slow, low speeds in low gears.
The quirk can happen when thr driver should stay in a low gear eg 1st or make the decision to accellerate or not, rarther than hovering on the throttle. It can be driven round fairly easly by slightly changing the driving style at very slow speeds.
We do as said offer a map that helps to remove the driving problem that some expreience but its not a guarentee in all cases as sometimes its the use the car is getting or drivatrain faults thats the problem.
Regards Pete
Post #369017 2nd Nov 2014 2:49pm
nicks
as far as i know, just for the 2.2
Post #369757 5th Nov 2014 4:57pm
