![]() | Home > Puma (Tdci) > Will LR change the sump after warranty? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2468 ![]() ![]() ![]() |
Strange it was not changed before. If you do not do extreme off roading probably you are safe. Anyway it should be around 30 quid Puma 110" SW
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Maybe the previouse owner never serviced it at a dealer who would have done it as part of the service
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
Does anyone know if this was a recall?
If so it should still be done regardless of age or warranty. A few years back I was running a V8 Disco 1 that was 11 years old. Land Rover issued a recall due to potential fuel tank leaks and my local dealer fitted a new fuel tank free of charge. Only thing I would have had to pay for was the labour for removal & replacement of a tank guard or tow bar (although I had neither). Not so sure if it just a technical bulletin? MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
No recall, just TB Puma 110" SW
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
No it was a recall in the UK I had the call from the supplying dealer back in the day...shame it had already been done. There is a post on here from me about the recall status and as if by magic: http://www.defender2.net/forum/topic512.html Mike |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17722 ![]() ![]() ![]() |
I did form the impression from the info on this forum that the sump and the possible chafing of brake pipes were both recall items rather than service items. If so, I would expect LR to do the work irrespective of age and warranty status.
My 'new' DC was sold new by Hereford Landrover and received its first service from them (the invoice was included with the vehicle documents, and included the fitting of a new clutch slave cylinder). Subsequent services were carried out by an independent 'all-makes' garage (which I know) so any other service actions will have been missed. There is the usual oil stain on the bonnet indicating the vac pump seal failure, but I wiped much of the oil off and it doesn't seem to have come back, so I suspect that the vac pump has been changed too. Thanks for your comments, everyone. This foruim continues to impress me with both with the breadth of accumulated knowledge and the helpfulness of the contributing members! |
