![]() | Home > Puma (Tdci) > Access to the 10AS unit |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
You should be able to communicate to it through the serial port, there are no special leads or connectors required. I will be surprised if you can do it with the ldv kit as immobiliser diagnostics aren't usually covered by anything other than a dealer level or manufacturer specific diagnostic tool. I would be tempted to find someone with sdd/auto logic/ nano com and then it will probably communicate fine
my advice is leave it alone , if it's working fine , your temping fate
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
To access the 10AS with a diagnostic tool it has to be done with the ignition off.
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Thanks for advice lads,
I will have a go with the ignition off and if that does`ent work I`ll leave well alone. Knowing my luck at some point I will get cocky and end up killing the 10 AS ecu. Giving myself an expensive lesson in what not to do. ![]() |
